  • Replies 318
just starting out - use street tyres.
You learn your limits and control with street tyres. Do that for a year or 3 then get some semi's on seperate rims :D
No real toys to talk about,
Dejetro PFC and no airflows and greater adjustable top control arms, thats about it.
I would like to have a 2nd switch able oil cooler in before I go so I can at least have 10 min sessions.
P.S. I will only be in if the weather is cool, forecast for that week is hot
Wednesday 2nd Jan
Mostly fine.
West: Min: 18 Max: 30
Thursday 3th Jan
Mostly fine.
West: Min: 20 Max: 32
yeah im back in action for the time being. was a great day and lots of track time and not much traffic at all.
was soo much fun.... cant wait to get back out there agina.... but would have been great if i had some sort of timing, ill have to look into that in the near future. i was however having overheating problems with the watertemp getting up to atleast 120 most of the day/ will have to sort that out soon.
you little prick! you went with out me!!!!
ps. glad you had fun, I couldn't make it that day anyway
I'm thinking next week might be a goer for me.
well that was the best time i have had in ages!!!
had a few spinouts but after 4 or 5 sessions i was starting to drift that last corner nicely...omg so much fun! sideways forever!
i will going to these more often...
need to organise a big sau day out there~
its just gonna get expensive with the tyres and all...semis would be nice or atleast a harder compound.
oil got up to 130deg so ibetter get that cooler on and at one point my water temp was 105deg.
found a few bugs in my setup which i'll try and sortout before the next one...cant wait!
haha good to hear you enjoyed it out there. Always amazes me how gtsts can just go hit the track for a day in the middle of summer and survive.
ultimately a set of good semi slicks will be cheaper than wrecking your road tyres, but they are a bit tricky to learn track driving on because the better they are the less warning they give you when they are about to let go.....
In case people aren't aware
This was in the email I got weeks ago....
$130
From 2nd January 2008 to 9th January 2008 Grand Prix Circuit
11th January 2008 to 13th January 2008 Grand Prix Circuit
I have an exam on the 8th so........I could be tempted for another round anytime after that.
yeah price increase opf 10 bucks!
FW - when did you go - today??? f**k it was hot out there!! I got sunburnt at the beach, I was glad I had my r31 out not the 33!!
Id seriously suggest you stick to street tyres for a few more days on the track. learn the limits on them, then after alot of confidence etc etc, move to the semis.
bascially - do your bestest time on street tyres - then do semis :P
Glad you had fun however drifting last corner at OP with those walls - nah, Id pass!!!
every other corner yes!! but last corner? nah....and I can drift :D:thumbsup:
yeah today evil, was mad but hot. i will stick to street tyres for quite some time while i learn how to drive the car properly...
last turn is awesome....i found it the easiest to drift...
you found it the easyest because its off camber and thats y so many people end up in the wall so be carefull not that i can talk when i was there i was drifting that corner in the wet but i was doing it in a race car so if i crash that i can still get to work.
Where the hell have you been hiding Paul!?! :)
I had a month overseas and then I have been flat out with the pool fence business and usual work since I got back. Here is a pic you might like. When I get time I will start up a shameless promotion post.
+1 :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
