hey guys i have read all of the threads about ecus in auto r33s
all of them are from quite long ago
there would have to be advances in tech
so would are good ecus for auto skylines now
dont want extremely harsh gear changes
also i was searching on ebay for ecus and i found reprogrammed standard ecus
this is their description
Here is a Japanese tuned ecu by Garage50 tuning workshop this ecu to suit a RB25DET it puts out over 200rwkw @ 12.5 psi with only a front mount and dump pipe and 3" exhaust and bleed valve. it has the speed limiter removed and the boost cut removed also. If you raised the boost you will easily have over 300rwhp, and would get even more hp with a bigger turbo and other mods.This ECU puts out great low to midrange torque with the standard turbo which is great for drifting. Fully tested and working, I try to get all the ecus that i sell onto our dyno to check power output and more importantly make sure they have a safe air/fuel ratio and will run our fuel. We have had great success with these ecus and our feedback proves the results. This has been tested in both Manual and Automatic R33 Skylines series 1 and 2. This is the last one till Feb 2008 as i have stopped importing until next year.
has anyone had any experience with these ecus
is it worth getting somethinglike this and where would i get it retuned in wa
cheers
https://www.sau.com.au/forums/topic/196439-auto-ecus/
Dont overlook the PFC, I have one in my R33 GTSt auto and have had no problems, (as have others)
Have yet to find somewone who has tried a PFC and had a problem (others only know of "someone" that had the problem, but we can never find "someone" when we look)
https://www.sau.com.au/forums/topic/196439-auto-ecus/#findComment-3515835
hmmm interesting, magical removal of things that don't exist.
This is a good enough reason not to buy anything from that buyer.
people call boost cut different things. boost cut is hitting a higher afm voltage at a lower rpm i think it was around 3.8v @ 4000rpm and 4.1v @ 5500rpm (i think). programs like the emanage, safc and remaps have the paramters to overcome this.
https://www.sau.com.au/forums/topic/196439-auto-ecus/#findComment-3516249
the wrx's run off a MAP sensor to read boost. when the MAP reaches a certain voltage then it initiates the fuel cut - same as ours except the ecu reads air flow rathe than pressure to cut boost.
the wrx's can be tricked by putting a restrictor in line with the map sensor that reads boost (in their boost solenoid). what this does is moves the boost cut threshold up by a few psi. we try to do the same with the emanage and safc. we 'trick' the ecu by making it read a lower afm voltage by inputing one that would not initiate the fuel cut.
https://www.sau.com.au/forums/topic/196439-auto-ecus/#findComment-3516383
pfc for the win.
enough said.
https://www.sau.com.au/forums/topic/196439-auto-ecus/#findComment-3517895
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
