Standard gtr wing
Blue - few bumps and scratches - suit repainting
$150
1 set of stock R32 GTR 16" Forged Rims
No Tyres
$750 ono + Freight
1 set of BBS RK 18 inch Rims 5 x 120 PCD -
have a bit of guttering / scratches.
With Hub adators to suit GTR
No Tyres
$1150 + freight
($900 without adaptors - will fit BMW)
post-24243-1197887771_thumb.jpgpost-24243-1197887788_thumb.jpg[
4 x Silverstone FTZ Sport Tyres
(2 x 70% , 2 not Roadworthy)
$200 the lot
PM or Email [email protected]
:P
Edited by Antimatter
hey
Thanks so much for your input guys. Yes the 16 inch rims have some minimal gutter marks (nothing severe at all) I am happy to take some higher res images and email them to people who may be serious about buying them.
With regard to 400... hmm Nope. I'll hang on to them for that. But thanks all the same!
Bottom left one appears to have gutter scrapes on the bottom right hand corner of the rim
they are 18x8.5 - with the hub adaptors they work out to be +3 offset
This sits the face of the wheel in roughly the same position as it would if they were 18 x 9.5 +15 (nismo fitment for R33 an 34)
work fine as a street wheel - but probabley not the right wheel to try an squeeze 275 Track tyres on.....
(235 to 255's go on easy though - I might try a 265 on them next week if I have a chance)
what width and offset are the BBS wheels?
And without the hub adapter? Im looking at them for a Stagea, which is similar to a GTST offset
Cheers
Tha hub adaptors also change the PCD so it will fit the a GTR (the wheels are BMW PCD) - so probably no good on your Stagea. Sorry.
Cheers
Honestly - I have had that many lowballers on those rims. I threw them up on ebay as the had free listings for a few days (and didnt pay much attention to the price.... oops) - and with ebay there is no negotiation anyway. I will consider a serious and realistic offer ;)
Cheers
Cheers
  • 1 month later...
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
