  • Replies 47
Posted Images
abu - yeh im dealing with dennis, he sold me my first and was a great car mechanically.
James - asking the question coz i like both. not because i need reassurances of any sort on how much attention eithe will get. plus i dont live in denial, i live in general. lol
go RED!!...... oh..
i would go with grey. yellow if you want the exposure and attention. Grey..well yeah grey. better.
good choice Dan
congrats on the unfourtunate events that turned out fortunate
id personally go yellow for a few reasons
-rim choice wouldnt matter, black rims look good, so do white, and everything in between
-it dosent have a damn nismo kit, every r34 i see has one "its different.. its got nismo kit from factory.." NO!!!
-yellow looks good in day time, and also looks unbelieveably tough at night time, esp if you have xenons, seeing yellow/white cars in the rear view with xenons turns me on!
-black accents stand out much better in the car bits of the front bar? anything you want to add exteriorwise. maybe canards?(loook at a lamborghini in yellow all the air ducts etc)
-carbon fibre would look nuts on yellow
- +1 for yellow grabbing the chicks
thtas all i got so far!
yeah thats why i dont like silver cars. so hard to find rims that suit it....
yellow on black rims/steel lips would look nice as.
but either way congrats on the purchase, verrry nice :banana:
the rims i got for it, my 19's, will go good with either colour.
SS8_GOHAN: yeh i am keeping the ZENON lights. we worked it out with him.
Paulr33: bought from a dealer as i got a good price, bought my first car from him too. was too hard to find a good car at a good price privately.
Pav, Tony, soon as i get it we'll organise something. and tony, definitly wanna run it at calder stock just to see how it goes.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
