Hi all,
When i get my car back next month i will be pulling the turbo off and will be sold,along with braided oil and water lines.
I purchased an 0P6 housing and had it matched with my turbo.Then it was highflowed at Precision Turbos.
Highflow consists of machined front and rear housings(maximum)
Garrett Ball bearing cartridge.(will try and find the serial number for the cartridge)
It also comes with braided oil and water lines.
It has only been on the car for roughly 7000kms and is basically brand new.
I made 250.9rwkw at 16psi with this turbo.Has alot more in it and wouldnt be suprised if it would make 270-280 with a bit more boost.
The rear housing cost me $350
Braided lines $200
Highflowing of turbo $1550
Im asking $1650+post firm.
Old turbo off new turbo on.... big power!
NOW WITH FREE SILICONE INLET PIPE(second hand in excellent condition)
Bass Junky type.
Contact by PM.
CHEERS
https://www.sau.com.au/forums/topic/197284-highflowed-rb25vg30-bb-turbo/
  • 1 month later...
OK everyone i have finally got my car back so the turbo will be coming off the car.Those who sent me PMs for the turbo please get in contact with me before it goes to someone else.
dyno chart?
comes with reciepts/warranty?
direct bolt on for r33 gtst s1?
reason for selling?
Doesnt come with a warranty.But the thing is in great condition,i wouldnt be selling it if it wasnt.
Reason for selling is i have another turbo waiting to go in.And it will bolt on no probs comes with braided lines as described in first post.
is the just a standard r33 highflow? fitted it yet?
Sure is mate. Would have loved to buy NYTSKY's turbo its a very well spec'd hiflow but mine was too much of a good deal to pass up.
Its getting tuned today, I'll post up the results tonight after I've taken it for a drive.
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
