Well it is all happening!
We only have 6 odd weeks to have the car reliable, guaranteed we are coming back with a blown this or that... but also the thirst for a somewhat competitive car in 2009 - you gotta start somewhere!
Duncan - our only legal option is to run the ceramic turbos is it not - or have them rebuilt with a steel wheel CHRA? Someone mentioned earlier that to swap to N1 we would need to be entering the car as N1 spec and actually have an.. N1.
Can't wait to get over there!
  • Replies 60
You DON'T actually have to have a genuine N1, just enter it as such. But, you need to have all genuine N1 bits on there, such as factory oil cooler, N1 spec turbos etc. I reckon it'd be worth the exercise just to have that little bit of extra reliability up your sleeve.
Keep in mind that technically you cannot run a GTR with so much as an oil cooler if it wasn't on their from factory. Hence nearly everyone runs as N1 spec. :O
Btw, great to have another Skyline there :D
Edited by Marlin
You actually have to have a genuine N1, just enter it as such. But, you need to have all genuine N1 bits on there, such as factory oil cooler, N1 spec turbos etc. I reckon it'd be worth the exercise just to have that little bit of extra reliability up your sleeve.
Keep in mind that technically you cannot run a GTR with so much as an oil cooler if it wasn't on their from factory. Hence nearly everyone runs as N1 spec. :D
lol you forgot a very important word 2nd in that sentance "dont"
but you are right about the trade off. the n1 turbos are too big, but 16" wheels are too small. lots of compromises.
Is an N1 oil pump required?
I am thinking the higher flow is more likely to cause oil issues without any internal engine mods to oiling for the head. We are trying to avoid cracking open the motor at this stage.
Also just trying to get our hands on some N1 "lagmasters" - one guy looks to have the R34 N1 dumps as well which could be a good bonus - you guys know of any issues fitting these in the 32 with the standard front pipe positions?
Oh and if anyone has an N1 oil cooler, power steering cooler or water pump we are in the market BIG TIME!
Edited by paulR32gtr
well strictly yes, if you run in n1 spec you can't pick which bits you want. but the n1 pump flows less not more than a standard pump. also targa seemed to be easier on the motor than circuit racing you are not doing as much sustained high rev stuff (yes on the big straights, but there is a lot of mid rev tight stuff too)
re the 34 n1 dumps, they of course are also not legal on a 32. I am pretty confident they would bolt straight on though, only difference would be the rear dump has an exhaust gas temp sensor fitting.
i had to get my 32 n1 turbs from nissan on order from japan. no-one else was mad enough to want a set of them I guess :( the 34 n1s are a much better unit (ball bearing v 270o thrust bearing) but not legal
having said all that, I didn't notice any eligibility scruitineering last year at all. Another GTR we went through with clearly had aftermarket injectors for example.
Sweet re: oil pump - Steve already bought one! I do now remember hearing that they flowed less - thanks.
How much were the R32 N1's and how long did they take to get here? Edit: spose i should just get on the phone to nissan eh!!
We are looking at the G4 Racing AP copies - just hoping they will fit under 17x8 / 17x9 wheels
Ben you mentioned being able to run 18x9 under the option rule - what does this entail? Couldn't find it mentioned in the regs.
Stu Benson (tech reg guy for Targa) has told me that cars are alowed to run wheels that were option parts. The R32 GT-R had 17x9, and 18x9 wheels as an option from the factory. R33's had 18x10 optional wheels from the factory. The old CAMS regs had the option rule in there somewhere. Best bet is to email Stu.
Just found the regs. 301.9 http://www.targa.com.au/Competitors/Regula...icalGeneral.pdf dosn't say anything about wheels though?
Hi
Re the options on wheels, I read the new regs and it does not say you can have option wheels so I am not sure you can.
The other thing to remember is that if you run an option you need to be able to produce proof as per the regs.
That proof must be in one of the formats defined in the regs.
Just my thoughts, happy to see the rules that say otherwise.
BT
wheel options were removed in error from the regs, but will be re-included via bulletin shortly. sorry for the confusion.
paul - further to your email, lee also took the turbos off my old GTR and replaced them with something else. i doubt he'd be after big dollars for them. they made 260kw on 16psi and 95ron with a 3.5" exhaust with a very very mild tune.
Hey whats the deal with exhaust regs?
Had a chat with Ben @ Racepace and he mentioned we may be limited to a 3" exhaust maximum on the GTR? Ouch...
Stuart - those turbos were genuine N1's?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
