Wheels Sticking Outside The Gaurde
29 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok now have i missed something....?
Where was i when it was decided that rims and tyres that stick way out side the gaurd was cool and a good thing???
Apart from the obvious, massive rubbing over bumps, defectable etc etc it looks stupid. (thats just in my opionion of course)
Who started this trend and why would you do it for!
what do you guys and girls think??
end rant! :devil:
I don't see anything wrong with it. With the Stagea above, I wouldn't want anything more 'sunkin' in.
For me, I want the wheels to be even with the guards, anything less is :devil: in my opinion.
i agree even with the gaurds, wider the better! but not to the point they move outside of the gaurd!
I don't mind the wheels going outside of the guards on some cars. On skylines, I prefer the wheels to be flush with the rolled guards and on silvias I like the wheels sticking out at least an inch from the standard guards, but then I would flare them out.
It really depends on what car it is.
If it sticks out, it needs flares to make it even again.
Yeah, you need flaring done if the wheels are purposely made to stick out. If you're talking about not flaring and just making the wheels stick out 2", I find that stupid as well.
agreed the stagea up top looks ghey cause stagea's are very slab sided.. to get away with the look on one of those you would need to massage the gaurds out
i think the wheels sitting slightly out of the gaurds looks f**kING GOOD, but to pull it off you need stretched tyres to keep the treads under the gaurd itself, and maybe some slight flaring too
It gives the car a wider, meaner, tougher stance IMO....also means you can have wider wheels :domokun:
It gives the car a wider, meaner, tougher stance IMO....also means you can have wider wheels ;)
how does having wider wheels help when they have smaller tyres anyway?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
