Not sure which way to go. I'm interested in both of these
R34GT + Late model car etc (rare version available)
R34GT - non I can think or am aware of.
R33GTR V-Spec + well it's a GTR & V-Spec! already modified
R33GTR V-Spec - modified, possible issues later on & insurance. Older car
Both similar price, both similar K's
Without being to specific or negative in respect to relevant members, I would appreciate any sugestions or opinions.
Thanks
https://www.sau.com.au/forums/topic/19778-r34-gt-or-r33-gtr-v-spec/
I chose the 34 GTT myself, wanted something 'newer' in all respects of the word. I am paying 1,200 full comp with shannons. 33 GTR was a bit more expensive when I bought mine
newer engine, looks, styling, etc.
As Straight6 said "drive them both" :D and also look at them both inside and out!
Have fun.
if you're looking for a Skyline for the sake of it being new, get the R34 GTt, if you're more inclined to performance, go the R33 GT-R cos at the end of the day you still got the RB26 under the hood.
.......or better yet the R34 GT-R:burnout:
i would go the R33 GT-R VSPEC.:D i might be the only one saying this...but i prefer the R33 shape to the R34 shape(considering both are GT-Rs). Especially a S2 R33 GT-R VSPEC in midnight purple with white RAYS TE37s:p
I did the same - R34 GTT vs R33 GTR. At the end of the day - I chose the GTR. Why? A GTT, although newer and very nice - will never be a GTR. I didn't want to spend lots of money on a car that I wish was something better.
Just my 2c :D
Either way - you can't loose.
Oh - Aerograce: Like this?
I've seen 33 GTST's in Midnight Purple but not sure if they are authentic factory coloured or R customs. There is like a 40th Anniversary Edition (might B Tommy Kaira) of the R33 that i've only seen in White and the purple so maybe it isnt a GTR exclusive........Oh and just to reinterate - GTR all the way baby!!!!!!!
Originally posted by Jamezilla
:drooling: :) Beautiful, beautiful car...
hey james, were u driving down St. Kilda rd towards flinders st and like 4pm Fri arvo, heard a nice exhaust walking down Dorcas, turn around and see an awesome midnight purple R33 with what looked like bronze rims cruising along. Def GTR too, i assum that was urself??
so is ur pride and joy (no, not the Lada :D) all back in working order?? been quite a while hasn't it?
anyways, i'm sure a R34 GT-T would be cheaper too, whilst i'd prob go with the R33 GTR V-Spec if the price wasn't a problem, but if it was i'd prob go with the GT-T
cheers.
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
