how much louder are we talking.?
i had my exhaust tested, 84db, nice and quiet, but i'm about to install a high flow. i always knew it would make things louder, would an increase of 7 psi make a huge difference in noise?
i am installing a gt30r sitting on a custom made high mount with 44mm turbosmart external wastegate and with a 3/or 3.5 " wide mouth dump
im sure the level of noise will increase, but would it be worth while upgrading my 3" jasma exhaust? or power difference from another exhaust wouldnt be noticable?
im pretty sure its the standard exhaust, but i have had the middle muffler removed.
The stock exhaust system is tiny, does it have twin pipes at the end? I would get a new one, go stainless steel 3" with 2 mufflers. Just be aware of the noise issue that will result with the bigger turbo, more flow = more noise.
bigger turbo= more flow= more noise? makes sense.
is there a possibility of upgrading the turbo and still having a quite car at low rev and an insane one at high rpm range? i too would enjoy to stay under the radar but would love to have the rb scream when i wanted it.
thanks in advance
bugger, haha i'll see what happens when i get my car back from the shop.
had a hiflow on it previously and was fairly quiet. Was actually considering then to get a new exhaust with less turns in the pipes.
but looking at what you have said i might wait and see what noise level i am on.
mine was 93-4, now is over a hundred again still with the peII. i want to put the old exhaust on again and see lol it used to be 100+ on the stock turbo.
i guess turbo choiuce is a bit different to you guys tho. right now car idles like open pipes with the peII
get one of those valves for the exhaust where you can turn it from inside the car to cut sound (and obviously flow/power) then open it right up for full sound and power.
Do you know the name of it? who makes them, HKS? anyone heard of such a valve?
you can get them from autobarn etc up here in syd quite easily. that "drift" brand make them and are probably the cheapest. also hks etc have similar offerings. they are called exhaust control valves (ECV) or exhaust valve controllers (EVC) by most manufacturer's., and are basically a throttle body for your exhaustdrift ones are around 170 bucks
www.nengun.com
I got my apexi one off nengun. They are quite good. Factor in a few hundred install. Had to remove my whole exhuast (one piece dump to cannon), cut in half, take a 150mm piece out. Weld on flanges to the exhuast and then flanges to the evc and then bolt back in.
I was hoping quiter on idle but make no difference. But if u tap accelerator with it shut it sounds like a camry. I have straight through 3" with just a cannon, and it gets very quiet when closed (rb20det with highflow)
what about that,,, im unsure of the brand might be xforce.
it comes with an electronic solenoid built in that diverts air, baffleing it making it quieter.
it was tested on ignition dvd. and sounded nice and quiet. then when u press the button, it unleashes hell
Edited by r33cruiser
Does the TRUST PE2 exhaust have 2 mufflers?
as in one out the back and another between that and the cat?
if not, get an exhaust place to fit a 3 inch off centre muffler in the middle somewhere..
that'll shut the thing up.
EDIT - not I said muffler.. not a resonator.
they don't do shit.
Edited by GTST
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
