Drive line loss is going to be greater in the GT-R and the power weight ratio would come into play but its hard to quantify as the AWD has such an advantage of the line especially in street trim-check out the drag times, specifically the 60 footers. I'm sure someone will have a go at this one but if I had a GTST and wanted to keep up with a GT-R I'd get Roy to drive it. See the youtube videos for driving tips. :laugh:
https://www.sau.com.au/forums/topic/198065-awkw-vs-rwkw/#findComment-3538007
I did the double in my 32 GTS4 (RB20DET). It had 145 rwkw and 115 awkw.
Using that as a comparison, I'm guessing that a 230 awkw GT-R would have something approaching 300 rwkw.
did you do the 'double' on the same dyno? ie drop driveshaft after awd run and test again on same dyno, same settings etc
just that, in general, there ISNT that much of a drop between rwd and awd.
somewhere between 5 and 10% difference is more like it, taking into account drivetrain loss
other people to test back to back have found results more like 220rwk to 205awkw
In my mind, a 230awkw gtr would put out around 250rwkw with the front driveshaft dropped
https://www.sau.com.au/forums/topic/198065-awkw-vs-rwkw/#findComment-3538307
The question asked is so impossible to answer it makes this thread pointless.
Every set up is different, power delivery, traction and so on.
As for awkw - rwkw, bugger all difference. People have tested it here before, nothing major to note down as a GTR isnt full time 4WD
https://www.sau.com.au/forums/topic/198065-awkw-vs-rwkw/#findComment-3538312
so if my gtr is 300kws at the rears you would say it would be near enough 300kws all round?
https://www.sau.com.au/forums/topic/198065-awkw-vs-rwkw/#findComment-3538327
Actually this could be guite a good thread if some decent information comes up.
I'm sure i'm not the only gtst driver that is thinkin bout the R upgrade, but is not 100%
its a hard choice after dropping 15k odd in mods and having an awesome street car...
https://www.sau.com.au/forums/topic/198065-awkw-vs-rwkw/#findComment-3538409
*returns after some very BASIC maths type stuff*
ok so on a strictly power to weight ratio...
a 230awkw 33 gtr is around 250rwkw and weighs around 1.55ton which gives it a power to weight of 161kw/ton
to match this power ratio a 33 gtst weighing around 1.35 ton will need only 220rwkw to make 162kw/ton
this of course does not include any of the factors that make gtr's superior cars... Just power to weight
https://www.sau.com.au/forums/topic/198065-awkw-vs-rwkw/#findComment-3538458
I have just made that decision... had a 33 gtst and added up all the things i wanted to do to it etc and it ran nearly to 9000 so instead sold the 33 for 18000 just the other day and have saved the 9000 so looking now for a gtr 33 for around 30000....
GTR badge reali draws me!! lol
https://www.sau.com.au/forums/topic/198065-awkw-vs-rwkw/#findComment-3538479
Power to weight has ALOT to do with it, but then again so does torque (specifically for straight line race). Its simple maths really when neglecting things like traction, driver differences, and other similar factors. But then torque comes into it, but there isnt realy a way to factor this in fairly. Fact be it tho, torque generally will help immensely in a striaght line.
https://www.sau.com.au/forums/topic/198065-awkw-vs-rwkw/#findComment-3538728
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
