Damper Setting
I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕 hope it is not gearbox out. I will let you know.
If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
@GTSBoy iam not a mechanic so what could typically gone wrong? It can help my mechanic...maybe he just forgot something or something like that that could help. Yeah i thought. I took a LONG time to search for the right one. Yes i read about all of that and i give him a call about that. I look at those slave/master cylinders and they are not that expensive so i will be buying them anyway just to be sure. @DuncanYou think it can be short? I double checked if that was a right one(it came with the clutch kit) Ok i will give him a call. Hope it is some sort of "little error" and not some "yeah the gearbox needs to go out" one
Temporary. Sorry about the inconvenience while we sort some issues.
No idea. I haven't looked at it since sometime last year.
