ok, today i noticed 4 LEd's in my brakelight are out. this makes me think they must be wired in groups of 4 series to parallel.
anyways back to my query. replacing the 4 would be easy enough however getting the 4 to match the others perfectly would be hard.
can you buy these things seperately eg: from nissan...anyone know or would iot be easier to buy the whole light unit/ loom and all...
where from whats the cost.....
https://www.sau.com.au/forums/topic/19819-leds-in-brake-light/
Guest RedLineGTR
if we are talking about the rear brake lights, then just pull one of them out go to a local store and get a set of four, not to hard me thinks...you'll have to take off some of the boot trim to get to them, then you just uncrew the cover anti clockwise and bingo your lights..
mine went out and i cracked it open and took it too dick smith to sort me out with new leds/resistor.......the guy couldnt even figure out how it worked..bloody useless!! so i just got a friend of mine to get me a toyota one from work and i just ripped that apart and poped in...replaced the whole thing...sweet as!!
Alot of dick smith fellars have no idea. If some leds are to bright just put a varable resistor in the circuit to them. And change resistance till it looks correct. Never poped mine a apart though so, it's just a thought.
If u r realy tricky you could set up a circuit with the three color led's and get them to change by siwtching them, or run em through a micro and make some cool flashing affects. Well that would be cool, but in a bit of a fantasy world now. :-)
oh shit sorry dudes, i fixed it the other day but forget to check the thread.
for everyones information the brake light in the r33(the one in the spoiler) is wired in groups of 4 serial leds then those groups in parallel. it turns out that the third group on mine wasnt working, after using some logic i found that one of the dry joints wasnt soilded correctly. i tried to fix this but still didnt work so i took the easy way out and bridged the connection with the next set of leds and everything works fine. :)
  • 5 months later...
I'm having a problem with none of the leds working and I believe its the diode, but can't get into the sealed unit. How did you guys get into it? I've sat down with a stanley knife and tried cutting into it, but doesn't seem to budge and don't want to screw it...
I was quoted $150 for a 2nd hand replacement upon trade in of my screwed one because they can apparently fix them and resell them...
I have a new one you can have for $150... unused in nissan box , I think it was about $260 from nissan by the time it arrived from backorder car had been written off
Yeah, it's a bitch to open... You have to persevere though. We snapped a blade in the process, but once you get it started, then it's easy. Beats paying $150 when all you gotta do is replace a two cent component :P
bridging is the key :O
thread back from the dead :)
Thanks Guys. Haven't had time to have another crack it and don't really want to screw it up either or I might have to take you up on that offer jake32. It is a R33 light you have isn't it?
So Stanley knife is the way to go to crack it open? You guys didn't use solvents or anything to assist?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
