What do you guys think? I've seen this conversion at some shows here, and I think just from weight distribution alone it would be a good idea.
Right now I've just just got a stock shitter R32 4-door Type M... 100,000k's, couple of dings here and there, but this ones gonna be my long-term ride... hello engine swap.
Would anybody contemplate removing an RB from a Skyline?
https://www.sau.com.au/forums/topic/19830-rb20det-sr20det-in-r32/
Why would people say it's going backwards? The capacity is the same, the SR (chosen carefully) would be a newer engine, the power is virtually the same...
Alot of guys here in Japan either bomb the crap out of the RB20, or get rid of it.
the torque thing is a bit misguided.
YES the SR20DET makes more torque than the RB20DET.
SR = 155kw@6000rpm and 275NM@4000rpm at 8psi boost (ROUGH numbers)
RB = 158kw@6200rpm and 263NM@3200rpm at 8-9psi boost (rough numbers again)
the RB makes like 10NM less but at 800rpm earlier.
so whish engine is actually the more TORQUEY engine?
the one that has a little more torque or the one that pulls from lower revs?
hope this adds to the discussion.
I saw this conversion done in Japan while I was over there ( Osaka ) and it seems the main reason for doing this RB to SR swap is for race or drift purposes. The main thing is that when an SR is fitted, there's so much room between the radiator and the engine that you can bring the radiator and intercooler back into the engine bay for protection against front end damage.
Most of the ones I saw then ducted the air path up through the bonnet which keeps the air heated air flow away from the engine itself but about 1/3 of the air hitting the front of the car actually goes into the engine bay.
One of the guys I spoke to over there also swears by the reduction in front end weight and the great change in weight distribution. So if your RB is dead, go an SR instead !
Yeah, that flat-mounted-in-the-engine bay intercooler setup is a definate goer... theres actually a flat-mount intercooler for 180SX's with extemely short pipes to and from the turbo/intake manifold which I'm looking to export to Oz.
FAT32> I'm in Osaka/Kobe. Who did you speak to?
Rezz, I was talking to one guy at the Osaka Auto Messe who spoke english rather well and that's where I got most of my info from. Didn't really talk to any workshops etc. about this subject. ( Don't speak enough Japanese to hold a conversation ).
I love the conversion from RB to SR it just makes so much sense and it looked awesome in his red drift R32 !!
Was that this years Messe, or last (or one before that)? Mate, I saw a couple of Aussies (I can tell a countryman in a crowd of Japs no problem!:) ) there, I wonder if it was you?
Anyways, I love the conversion too, ESPECIALLY after Nismo retired the RB26 in the '02 JGTC in favour of the VG30DETT, for better weight distribution amongst other things...
I went this year ( Feb 03 ) and I should be going again next Feb if all goes well. The year before I went to the Auto Salon in Tokyo but that's just too packed for me. You know, you probably did see me there. I think I was causing a bit of a disturbance by drawing the promo girls away from the hungry flocks of Japanese camera jockey's. He, he. :D Got some great pictures from that trip.
I've got a mate who lives over there called Alan then another mate called Gary who also joined us. 2 Aussies and a Greek in Japan, way too funny !
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
