Hi all,
I have purchased a Garrett GT3076 .82 turbo,along with GCG highmount manifold and Turbosmart ex gate.I was wondering if some members could post some pics of similar setup as so i can get an idea of how they have set their wastegate plumbing.Ive heard that this will be important to get right.I would like to go screamer option(until i get annoyed with it) for a while as the car will mostly be used for track days.
Hoping to crack 300rwkw with this setup.I already have Poncams and will be running 18psi.
The motor will be built in the coming weeks(months) as i gather the parts, but will still run the car with this turbo until i pull the motor out.
Happy times.
CHEERS
P.S Lithium saw your car on YouTube,good to see both .63 and .82 comparisons.
https://www.sau.com.au/forums/topic/198404-joining-the-gt30-ew-club/
What do you mean by the gate setup dude?
The manifold should accommodate the gate.
Then all you need to do is put it on really and get someone to make up the rest of the piping for the screamer/plumb and so on.
Meaning.Does the pipe off the wastegate need to be a certain length if going the screamer type?
Or does it need to be plumbed in along the dump pipe at a certain point so i dont have any flow dramas?
Ive heard if the wastegate pipe is plumbed in at a bend it can cause hassals.
Correct me if im wrong.
I had my ext wastegate plumbed back in at the bend and flowed an easy 330rwkw @ 18.7psi on stock cams...
3" Exhaust system all the way through and a high flow cat...
I also had a GT30 0.82 and a high mount manifold... Same setup...
Hi Col,your turbo was a GT30/40 wasnt it?
Sorry yes it was... :D
The first of them when they put in the dual BB cartridge...
EDIT: Reguardless I dont see a hassle plumbing it back in at the bend, does not matter where you plum it in its gonna cause a slight disturbance to the flow. Just have the shop plumb it in at the least angle possible, to help the flow... But to be honest the exhaust pressure at 300rwkw is like opening up the flood gates at a dam...
Yeh your right.How do i go about the whole mocking up process for a dump/screamer?
Would i need to tow the car to my exhaust shop? Create a template of some sort and get it made up?
Just tow it to the exhaust shop and let them have it...
Mine cost $280 that was a new dump from the back of the turbo and a pipe from the wastgate all back to the cat...
I think that was an awesome price considering they spent a good 4 hours doing it...
I am looking at getting the gcg high mount manifold too, these are the pics i was sent.
In these pics it seems to me the pipe the gate mounts off goes towards the front of the car and not the rear, and im not 100% sure that is right.
Do you have and pics of your manfold BOOSTED? Also any reason you went the turbosmart gate and not the tial??
cheers
dont u guys think that a 3076 is abit small for a 2.5L engine??
i would personally go with a GT35 series turbo on a 2.5L engine
Nope, IMO they are the perfect size.
Having had a 600hp GT30 turbo on a 2.5ltr motor, i wouldnt do it again. Just too unresponsive for a street driven car.
GT35, 700hp, too big.
Decent power @ 4500rpm doesnt make a fast street car.
My RB26, GT-SS setup feels heaps faster @ 250rwkw than my RB25/GT30 setup did @ ~280rwkw because there is power everywhere.
Its a good design.
The did have issues with thier older models cracking and what not, but this was going back a few years.
And since then a few cars ive been told are running without problem that use them
alternatively there are a few local makers now producing good products
6boost
Extreme Turbo Manifolds
etc etc
Cheers ash,
im pretty familiar with what else is around i was really just concerned with the way the pipe that the w/g mounts on appears to go towards the front of the car, rather than the rear. I know they wouldnt make something that didnt work but just thought i would throw it up here for discussion. :D
Edited by 2630GTS
Nah you'd attach the gate upside down
Then the screamer pipe would be pointing towards the REAR of the car if you turn the gate and have the outlet facing the rear
If its made for an R33 RB25, then clearance wont be an issue.
cheers
that looks 2jz ish or maybe the photo is inverse.... cause why the hell would you run the gate that way???
EDIT: just had a close look and im 99% sure it is 2jz or 1jz. i think that is just a pic they use for refferrence.
Cool congrats on going with that setup, look forward to seeing how it goes with cams etc.
Would you like to post your RB26 GT-SS dyno plot? It would make for some interesting comparison. I overlayed my .82a/r GT30R dyno plot with my stock turbo one and I have overtaken the stock turbo by 3500rpm, so you are effectively saying the RB26 + GTSS will make better power everywhere than an RB25 ever will - perhaps short of putting a smaller than stock turbo on it and converting it into a tow setup.
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
