Wiring an Amp in a R33
Guest thfc1afc0
To anyone who has an amp wired up in their 33, is it earthed to the battery earth or has it got it's own earthing point ? If so where is it ?
I wouldn't have thought it would make that much difference, but really don't wanna fry my amp after spending the best part of a day creating a custom unit to fit next to the battery containing my amp and multichanger.
Cheers
G
https://www.sau.com.au/forums/topic/19893-wiring-an-amp-in-a-r33/
yeah i did all that myself, the battery is still in its original position, the hicas computer was moved to the middle of the parcel shelf to fit the speakers in. They are alpine type r 6 by 9's in for rear fill, Type r 6 1/2 splits up front Type S 12 subs with and Alpine MRV-F540 and an alpine MRV-T420 powering it all. The amps are located behind the subs on a piece of mdf mounted on the fake partition in the 33 boot. The grey u see is just a vinal trim piece and the box isnt much bigger then the whole cut out for it. and the base of the box is just 19mm mdf the is much longer then both sides of the box so i had somewhere to screw the bow into the floor. It takes all of 5 mins to remove so i can still get to the spare tyre.
  • 1 month later...
NA_R33 i like the sounds of your system, at the moment I have a M500 mono block running a 12" JBL Powerseries, i have type r 6 1/2's in the back, F#1 Status splits in the front, 307 running all the speakers, alpine tv and vcd changer, and sony PS2, and a stinger capacitor. i am looking at going to 2 jbl's and a m1000 (around 1200 watts rms) and a new alpine 4 channel. I had type r splits and loved them, but after going to the F#1 Alpines i would never go back.
the dual voice coil type s is a very good sub for its price, If you are willing to spent a little extra the type r is a very good choice. I had a type r and it really went off, but the JBL is just that little better. I put a type s in a mates corolla with around 200 watts rms behind it and it goes of its head, he got the sub and the m200 amp brand new for about $450, and it really does sound good.
dude your whole chassis is negative, so you can ground your amplifier to any conductive material that is attached to your chassis, it will carry negative energy, when 'blowing' things up it has to have a power current running through it thus the need of positive but you counteract such things buy having inline fuses.....
-bryan
  • 1 month later...
BryanB,when grounding an amp which is close to the battery, it is best to connect the amp to the -ve terminal, or the same ground point. The reason for this is that by grounding at another point nearby can 'induce a ground looping inductance', which can leak signals back into the amp and cause interference. If the battery is a long way away, then there is little chance of this and a different grounding point is unlikely to cause a problem. I got this info first from my old man, and backed up by ppl at DLS.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
