Find someone who is good at photoshopping and get them to photoshop an S15 front end onto a photo of your R32. That way, we can all see what it will look like and go from there. I think It'd look weird, but it could work. Up to you. But what about a 180SX front end? Or something outside the Nissan camp altogether?
might post on the photochop section
we'll see ...
  • Replies 49
need to find a nice vertex r32 and whack the s15 front on, that wud look hot
yeh, would love to see ur work mate... :thumbsup:
there's already a four door yellow r32 with s15 front
why not just try and find a pic of it via google?
where.. could not find it!! can anyone post it here??
Edited by subie
S15 front on an R32 looks like arse, the S15 face demands a smooth back with curves, ie a S15 or a 180sx. An S15 front on an R32 looks like a S15 front on a S13 silvia with round taillights. The R32 demands a chunky front, to match the chunky butt. Even the S15 front on an S14 is kinda borderline for me, it works only because the s14's kinda rounded at the back.
There's a yellow S13 silvia in the US with an S15 front and Skyline tail lights grafted onto it. Looks like a steaming pile of shit.
For an R32 you want something butch... why not try a DTM style mercedes, audi or BMW front? Panels are readily available locally, they'll fit the lines of the R32 and it'll be quite different. If you wanna be REAL cheeky, grab a VE commodore frontend and graft it on. VE's look tough as fron the front.
it'll be even more sweeter if you do an LS1 swap which is getting more and more common in nissans these days... lighter than an RB25DET and makes more power with a LOT of potential for big numbers... plus it sits further back in the car further between the wheelbase, so it won't be as nose heavy.
this is the most bad ass conversion imo...... 180sx front on an s15 such a smooth transition in body lines.... unlike the s15 front on a skyline which is a pointy front end to a beefy rear which make it look hurtinnnnnnn it doesn't flow what soever
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
