My engine has decided to start making a new noise - if I go from off-throttle to full throttle at reasonably high RPM (3k+) in 1'st/second gear, I get a squeal like a slipping fan belt for about half a second (and yes, I have checked the belt, and no - it's not wheelspin). No noise if it builds boost slowly. I can also get the noise by getting the revs up to 4K then going full throttle for an instant - but it's so damned noisy under the bonnet I can't work out where it's coming from (but it's not the fan belt). I'm thinking turbo thrust bearing... any dissenting opinions?
https://www.sau.com.au/forums/topic/199128-turbo-beginning-to-go-on-rb20det/
Pull off the air box lid and filter, give the bitch a tweak of the throttle and listen to the turbo. You should be able to determine any unsatisfactory noise. Failing that remove the pipework and check shaft, carefully.
Yep, sounds like turbo bearings.
Had same thing. At first the squeal only came in under boost.
By the time I got home it was constant.
The best way I could describe it would be the "woooooooo" sound made by a crowd at the fireworks.
Even with turbo removed there was no real discernable play in the shaft. All turbine blades were attached. Turbo looked fine.
Rotating the shaft by hand the bearings felt a bit rough however even that was difficult to tell.
In the end, turbo replaced, no more noise.
Thanks everyone, but as the noise only occurs for about half a second, I don't think it's a leaking gasket or pipework. I also run a pod with 3" induction piping, so no issues hearing noises - but with the bonnet open free revving, all I can hear is serious suction noises from the inlet. A sticking BOV might be the answer if it is slow when closing.... I'll have a look at that next.
You will not hear the noise with the car parked and the hood up. The car will not be producing boost as it will not be under load. As stated the simplest answer is the best place to look first, mainly because it is the cheapest thing to do. There only needs to be a tiny leak, you won't hear it off boost but when on boost the pressures are high enough to make the difference.
... and as I said before, I can hear the noise when free-revving, I just can't work out where it's coming from.
And it's not the BOV. As an extra bit of info (left window open, driving alongside retaining wall so I can hear better) , the noise occurs for about 2 seconds in 1'st gear, and about half a second in 2'nd gear.
I think at this point, I'm just going to wait for the noise to change before looking further. It doesn't seem to be getting any worse, and it only happens when I abuse the car anyway.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
