the top intercooler pipe that runs past the radiator seems to get pretty hot. but then everything in the engine bay gets pretty hot. i never checked, but i assume even the stock coldside pipe would have warmed up quite a bit under there.
so anyone who has bothered to heat wrap, or ceramic coat the pipe....did it make any difference?
is it worth doing? or does the air pass through there so fast that its not affected?
what about the guys with the stock cooler piping. after driving, does your cold side pipe feel hot?
Edited by Munkyb0y
Not a brilliant pic, but gives an idea of my efforts.
Running an inlet temp probe just prior to the throttle, I found inlet temps skyrocketed with slow speed, low load, stop start driving. The exit air temp from the radiator is 80 degrees +, and heat transfer through those alloy pipes is very rapid. Basically you'd have to expect degraded engine performance and an increased tendency to knock with higher inlet temps.
I changed to a custom fabricated steel pipe, HPC coated, then used a ceramic wool and covered with sticky backed refrigeration tape.
Result was much reduced heat soak effect IN THOSE CONDITIONS nominated.
Running at higher speeds (80km/h and above) + loads the differential effect was much less pronounced. Not an indicator of anything other than the higher mass flow of air being less affected by the radiator discharge in those conditions.
so the trick is to not slow down and always have good airflow through the engine bay.... otherwise I need to wrap my nicely polished IC piping...
"Excuse me sir do you have any reason for speeding back there", "yes well I didn't want my inlet temp to get any higher as it lessens the performance of the engine..."
hehehehe
what actual inlet temps did you see during the low speed, traffic driving? and what temps at 80kph+?
how do these compare to the piping that's not heat soaked by radiator air?
there's also that reflective stick on stuff. it's supposed to deflect alot of heat.
this is another good idea. http://www.skylinesaustralia.com/forums/in...t&id=133021
Edited by Munkyb0y
Thanks for that link, i have been looking for something like that for a while, plazmaman sells piping kits with there top pipe like that http://www.plazmaman.com/shop/index.php?ac...m&itemId=21
or...or... think about this.
buy a GReddy intake plenum.
now thats using your noggin'
Im trying to keep my car as legal as possible when you pop the bonnet and the greddy inlet would be another inlet mod.
or ... or.... buy a Veyron!! :D
Not everyone has a cool $1000 lying around just to get slightly better intake temps and response.
Back on topic - I wrapped mine but can't say it made any noticable difference. However, I haven't actually shielded my pod yet, naughty naughty!
Nice work dale, makes me want to eat some garlic bread, LOL. PS I think with that insulation the HPC would be a bit of a waste of money, not much would be getting through the rest.
Yeah, it does look a bit like wrapped garlic bread :D HPC probably was a bit over the top but I decided to give it the best chance of success. Then the cast alloy pipe is affected by heat radiating from the manifold and top of the engine.
Correct to some extent. It's also about the mass flow through the inlet tract, with a reasonable velocity preventing the heat penetrating and affecting the air within.
I'd have to dig out some old notes I made while testing, but basically I was achieving Summertime inlet temps of 80+ degrees in stop/start traffic, idling at lights etc.
With the piping setup as pictured, it came down to ~ 60 degrees at an ambient 35-38 degrees.
Clearing the traffic light runs, with about 3km of constant running ~ 80km/h and a bit of throttle, it would come down to somewhere around 50 degrees or slightly under.
I ran some temp probes at different points under the bonnet, and on hot days the heat buildup under bonnet is significant. Those 270 degree pipe bends aren't a bad idea but you'll still get radiated heat affecting the air within them too.
I take it that the reflective stick on stuff is the tape you're looking at in my photo? It is basically a heavy grade alfoil with sticky back. Good, but I wouldn't use it by itself as a long term solution.
The Greddy style manifold may offer significant improvement over stock RB25 if trying to reduce heat soak.
out of info, but that's my experience and opinion.
cheers
Dale
Not sure but was there a mention of CAI in your setup dale?? Or if any sort of coating on exhaust housing and or manifold, of which both should minimise heat again to a certain extent its all about reducing the temps at the start as well more so..
from what i've been able to find, the air apparently travels through the piping at such a high speed (10's of metres per second) that the effects of a hot pipe are minimal.
the temps going in, as stated above ^, have a greater effect.
I just wrapped mine with heat wrap, same as the exhaust wrap stuff. Dale seems to have proven it but there is not doubt that thin Alum. pipe will conduct heat well when there is little airflow.
was there a noticeable improvement?
there's also this stuff, but it's gold :(
http://www.mmsport.com.au/productview.php?...d=Heat_Products
Edited by Munkyb0y
Yes, all true.
The manifold and turbo is all heat shielded.
The big silver box in my pic is a sealed pod enclosure with silver faced neoprene for insulation, and a direct external air feed. I couldn't afford/justify the down time or expense of removing and sending the manifold or turbine + dump for HPC coating. It was as far as I was prepared to go, but I proved to myself the value of the changes through the inlet temp probe.
not really...but it must with help with heat soak...but then again I dont drive my car that much in the heat or at the lights.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
