If they bolt right on, you'll probably need the 4 door bootlid as well. The edge tapers at an angle to match the light, where the 2 door one has a curved corner.
can anyone comfirm this?? if they bolt straight on and only need 4 door bootlid, i wouldn't mind to do this also .. like 4 door rear lights tho
cheers
You're going to need the rear bar as well.
From what I can see, I don't think they'll be a straight swap over. The part where the indicator is on the sedan's, the lights are more curved compared to the coupes.
My answer would be that it's not a straight swap over, but then it doesn't hurt to try it for yourself.
its a straight fit with some minor modifications (well it is when changing from 4dr lights to 2dr lights)
from 4dr to 2dr you will need:
2dr bootlid
rear bar
both taillights
to make the taillights fit, you gotta cut away abit of the metal where it slots in to make it sit neatly, at the bottom of the boot, you will need to weld a 5mm metal strip on to make the gap as small as possible like as if it was an original 2dr rear. you can get away without welding the metal strip on but the gap from the rear boot > rear bar (above where it says skyline) will be like 2cm or a bit more.
i assume it would be the same when going from 2dr lights to 4dr except for the welding of the metal strip and cutting away some metal to fit the taillights.
if anyone wants to do it, im willing to be up for a swap (ive got a 4dr) preferbly a silver skyline :D
i like the 2dr lights better, much more agressive and sexy looking
Edited by whyte
[QUO]its a straight fit with some minor modifications (well it is when changing from 4dr lights to 2dr lights)
2dr bootlid
rear bar
both taillights
i like the 2dr lights better, much more agressive and sexy looking[QUO/]
have you found a thread, going through this in more depth or have you done it yourself? because i agree with you on the 2 door lights looking tougher and much sexier :thumbsup: and i have been looking for a decent thread or some kind of write-up about how to convert to the 2 door lights on a 4 door. like this :D
Only decent pic i could find, was from driftfest.
Edited by Greasy
Not trying to sound rude to you all, but all of you guys are wrong.
I personally have converted a sedan to coupe tail lights (see pic)
None of the parts are interchangable. The coupe boot lids are wider. And the coupe tail lights have a bigger (note: much bigger) bulb holders.
Bumpers do not fit as well, you gotta redrill everything
Edited by Chang
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
