Hi All,
some of you may know that the Heat Treatments R32 GT-R has been in development in the off season and now is sporting a redeveloped engine/trans/turbo setup with the intention of going quicker. It is now back together and is now tuned and ready to run again with the intention of knocking its world record down a bit lower.
Its next meet will be on the 5th of January at Meremere in NZ, given it will be the first meet with the new setup I wouldn't necessarily expect any records straight off - but I'll be there and will post up results if there are any people interested.
Here is a link to HT's workshop updates:
http://www.htlracing.co.nz/workshop.html
Edited by Lithium
https://www.sau.com.au/forums/topic/199359-heat-treatments-gt-r/
  • Replies 48
Ive seen this car run on a very green track at Taupo and i must say it was truely amazing. Considering the car ran 7.67 and 7.77 on such a track, i have the utmost respect for Reece as it was all over the place throughout the entire pass. The front diff. broke at 3/4 track on the 7.77 pass and was a PB (read:on pace for new world record pass) to 1/2 track. All the best to Reece, Kevin and all the crew.
  • 5 weeks later...
Wow,
Bring on new world record boys.
All looks on track for this Saturday. Apparently they have done initial tuning/testing and going by the numbers etc which have been going around, its probably going to go "rather fast" :banana:
  • 1 month later...
Last weekend HT finally got the thing out for a meet without any niggles, and managed a 7.80 @ 182mph on its now getting old slicks. Looks like they are quickly coming to grips with the new setup, should be very interesting when they decide to start winding the power up!!
A 7.8 is pretty impressive for a shakedown run.What is their target 7.0s?
Not sure what their target is - I think they just reckon they can go quicker than they did and would like a mid/low 7. I guess there is the hint that people might be intending on giving them some competition so good to keep it on form haha. Lots of fun seeing it get quicker, nonetheless. Seeing a R32 GTR charge down the track in sub 8s really is a sight to behold, a lot more exciting than your typical tube RWD etc - looks a lot angrier.
  • 4 weeks later...
Hi Guys,
I'm looking for some good pics of the HT R32 to feature in a book. If anyone has some good ones of the engine bay and exterior (preferably on the strip) and would like them featured in a book, then please e-mail or PM me.
I only have a couple of days to get the last pictures together for the publisher ( we are already miles behind schedule), so any help in the next couple of days would be most appreciated.
The book is due to be released very soon and is all about the history of the GT-R, including all the road and race variants. It will be heavily concentrating on the engineering side of the cars, but will nicely feature all the models in good depth.
Thanks in advance people!!
Kind regards
Paul.
  • 8 months later...
The car never made it to Oz obviously, but it finally did some shake downs with its new engine/suspension/wheel & tyre changes last weekend and was straight back in the 7s with plenty more in it by the sounds:
  • 1 year later...
Just for the interest of those that way inclined, the lads seem to have been busy with the new bigger turbo setup and have done some testing at the strip and some suspension/alignment tweaking to get the car down the strip better and one gets the impression that its all heading in a good direction.
Last weekend Reece ran a single full 1/4 mile pass and recorded a 1.19s 60ft time (which is its best on NZ soil) on the way to a 7.8 @ 177mph. This run was done with too much clutch, so there was plenty available power not making it to the tyres - as many here would know the car is capable of >190mph trap speeds when the boot gets really put in so fingers crossed there should be some fun times ahead.
This weekend in the NZ Four and Rotary nationals event, with the drags on Sunday - fingers crossed there may be some interesting results to report for both the Heat Treatments guys and also Robbie Ward who will be racing his RIPS FED, which has to date run a 7.4 but I quietly suspect that it has a bit more in it yet :P
Weather was pretty aweful, they didn't get a clean run in that I am aware of. Fastest time I heard was 8 flat, I ended up getting sick of the weather and left so didn't see any of their runs. RIPS left without having a go, as well.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
