  • Replies 3.9k
Posted Images
The appearance of Ferrari's radical new nose innovation at the Barcelona test on Monday confirmed that espionage could still be a factor at the Italian team.
Alleged Ferrari spy Nigel Stepney no longer works for the Maranello based team, but the technical secret about the 'hole nose' nonetheless emerged in the pages of an Italian magazine some ten weeks ago.
Autosprint broke the story about the nose, including sketches of the innovation, in its pages in February, raising suspicions that the leaking of confidential and sensitive design data has not stopped, notwithstanding Stepney's firing and McLaren's $100m fine.
According to the Swiss newspaper Blick, Technical Director Aldo Costa was 'horrified' about the leak, confiding that 'very few' Ferrari workers even knew about the nose solutions when they were being tested in the wind tunnel.
Blick claims that an internal investigation into the leak is in progress.
awesome
Who cares the soft tyre is just a diversion from the fact the racing is so dire. Just gives people the false hope that someones option tyre will grain & stuff their race.
Bin refuelling.
Give em soft tyres that only just last the distance.
Kill the downforce.
Then we may get some racing.
they should never have left
how do they intend to mark the softer tyre since there will be no groove in the face of the tread to paint on that rediculous white stripe?
Well yes... Exactly...
I'd still like to see a ban on all those silly flaps and elements that protrude all over these modern cars, reduce some of their aerodynamic efficiency and make it so a trailing car gets a bit of tow... Also, I'd like to see F1 take the biofuels route... 1.8 litre turbocharged V8 biodiesel motors... Could you imagine the torque??? :D
Why do people keep winging about parity in f1? It’s the pinnacle of motorsport, why should they have restrictions? The cars should be using the best and most advanced of everything that they can come up with. If a team is loosing then they need to make a better car or continue to loose... If people say "to keep the cost down" well if you want to play at the top then you need to bring the appropriate $, why should other teams who can afford the development suffer for the team that wants to play the game but cant really afford it....
F1 should not be about making all cars even, it should be about the ultimate speed whatever way possible.
FINALLY!
Unfortunately there arent enough companies/car makers willing or able to spend the big bucks to complete like the top teams are doing. By cutting costs it allows more teams to entry into this business, because without any cars on the grid to watch, theres going to be no formula 1 to watch.
F1 cars these days now exceed the limits of the drivers ability, not the other way around which was the cse in 'the good old days'. So now they are having to regulate the cars so as to keep them at a level where both car and driver abilty are somewhat the same. With this comes ridculous rules and band aid solutuions to the ever growing list of pronblems. And when you have dipshits like Mosley in change of these things, we're never going to get real solutions
So once again, thank you NoW... you've done us all a great justice
Edited by ctjet
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
