  • Replies 3.9k
Posted Images
I think because he lost the engine during the accident rather than it failing and him stopping on the track he won't get a penalty.
Any engine changes occurring during the Friday free practice sessions are free, as the FIA wanted more cars to be on track for the FP sessions, than when the use of the engines in FP was counted under the two race rule.
Ahahahaah,
This is why Mark Webber is the best driver in the paddock///
Q: (Tomas Richtr - TV Nova) Mark, let's assume for a moment that you will stop a little bit earlier than the guys around you. Will it be difficult not to try to go too fast, not to over-drive the car in the first stint?
MW: These days every lap is on the limit. We don't really pace the grands prix that much anymore. We go as flat out as often as we can. So I'm stopping on lap three and after that I will have a long race, so we will go from there.
Rofl, pwn the shit outta that nosey journo, Webmeister.
Good to see Kimi putting down a better time in Q3 when it mattered as opposed to the Q1 and Q2 times...
Well done to Webber...if he's not just running stupidly light to get a good spot in Qualifying then he should do well.
And how's Lousie's form...everyone congratulated HIS team-mate but him. Completely ignored him. Maybe all the other drivers hate Hamilton as much as us and were happy to see HK beat him.
I watched ESPN's coverage of the qualifying (with british commentators) and they were so far not Hamilton biased like the iTV flogs, it was great :banana:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
