  • Replies 3.9k
Posted Images
reminds me of a race where Raikkonen was a lap or 2 away from the win in the Mac and had a suspension or tire failure on the straight....absolutely gutting stuff.
I remember that...the suspension exploded.
It was a gutting moment. Hes had his fair share...
I could never have predicted this result.
Who seriously could?
.....i seriously do not believe the way this race has ended...
was expecting massa to knock that steward out like i've seen sooooooo many drivers attempt to do when a steward comes running up and touches them after a retirement....I would've wanted to throw that guy over the wall he boosted massa over, but massa with the composure...
at the end of the day i'm glad Hamilton had that puncture, not just because it cost him some points, but for the fact that if he hadn't he would've still been in P2, and inherited yet another undeserved win when Massa's engine blew.
Shattered for Massa, he must have heard all the people screaming for blood after Lewis got past so easily. So hats off to him for a brilliant race. He was robbed. Good work to Heikki, but it was an inherited win rather then something he deservedm would rather of seem Glock get up....champion drive
Fark off Dezz... youre discrediting Heikki.
Sriusly.
Sriusly.
so?
he didn't deserve it. Massa did and you're a fool if you think otherwise...but that seems to be the case with you on more than a few occasions so maybe the end of that statement isn't necessary :P
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
