hi all,
i'm dave, i'm from canberra, i'v been over on R31club for a while... had a fair few R31s but about 2 months ago i upgraded to a white RS4s. i'v been trying to sign up here since i got it but i'v been having troubles until today!
just thought i'd say hi and hope to see you around!
D.
https://www.sau.com.au/forums/topic/199881-new-stag-owner/
hi all,
D.
well done dave hope you enjoy your stagea, let us know how she goes and keep us updated on mods and things
happy trails
leetom.
https://www.sau.com.au/forums/topic/199881-new-stag-owner/#findComment-3559884
hello and welcome to the fold.
nice to see another manual stag on here as they are few and far between.
what options did you get on yours etc.? and hafta post up some pics for the gawkers too please?
anyway just thought it would be nice to say hello and welcome
cheers oxford
https://www.sau.com.au/forums/topic/199881-new-stag-owner/#findComment-3560462
Welcome to the Stagea clan!! :)
Enjoy the awesome wagon that is the Stagea....the enormous boot space, the comfort, the handling, the performance (potential), the traction, the not-so-great fuel economy, and last but not least, the puzzled expressions and long stares from bystanders and passers by as they try (in vain it seems) to work out what on earth that car is... >_<
Have owned mine for nearly 2 years, increased its power output by about 40awkw, and still very happy with it :)
https://www.sau.com.au/forums/topic/199881-new-stag-owner/#findComment-3560556
thanks everyone, at the moment she's fairly stock standard, 81 000k when i got her, short term mods will be high flow filter, exhaust, cruise, towbar and new coil packs and clutch. eventually it'll get wheels, hopefully some dayz bumpers and then ill squeeze a little bit more power out of her.
fuel wise she was getting around 330k around town until i took it to sydney a few weeks back. she got 480k on the highway and since then she gets about 400k around town.
iv got a dodgey fone pic but i'm about to take her to victoria and along the great ocean road from monday so ill take some better ones then and put them up when i get back.
D.
https://www.sau.com.au/forums/topic/199881-new-stag-owner/#findComment-3562991
nice S2, its got the dayz front bar and side skirts by the looks, more than likely the rear bar then too, so youve got the Dayz kit as is
some nice 18s would look schmick on that clean stag.
nah man, that aint the dayz bar, i wish! it's just the standard one with standard rear bar and as far as i know, the side skirts came on most cars...? anyway, yeh plan is to drop it on some 18's when i can pull the cash out of my ass and find the wheels i want... looking for something like these below........ anyone seen anything similar around anyewhere???
D.
https://www.sau.com.au/forums/topic/199881-new-stag-owner/#findComment-3564227
D.
yeah thats just the factory bodykit. pretty sure you cant get an s2 without some kind of kit, the only differences i've seen is in the front bar - the two "pillars" (one each side of the rego plate) are sometimes in a "/ \" shape rather than the "\ /" shape on yours (and mine). Hope that makes sense.
https://www.sau.com.au/forums/topic/199881-new-stag-owner/#findComment-3564401
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
