i know its been covered, but every scenario is slightly different:
r33 gtst
management : pfc - no hand controller
parts going on:
nismo 555cc injectors
nismo in tank fuel pump
Z32 afm
splitfire coils
HKS 2835 pro s
sorry mate, but you cant.
The car won't start.
You need a hand controller to set the 555cc injectors, and the Z32 afm.
All other mods are ok and won't have any affect when you limp your car to the shop.
Can you borrow a hand controller from somewhere? like a mate? f**k if I knew you I'd send you mine to borrow.
the car wont start with the injectors tho will it....
might have to just be a tow jobby :down:
thanx guys
case closed! bailiff please excuse the jury
Edited by joeyjoejoejuniorshabadoo
For all the money you have spent already, and the small amount you are trying to save, its just not worth it. Say it runs super rich and stuffs your plugs. Theres a minium $20 to fix that. Just get the tow, dont be tight.
[edit] if you are with RAC/Q/V/T etc use them, you will get a certain distance free. Just say it wont start :down:
Edited by dangerous_daveo
Its a plug'n'play - as a factory replacement, thats what the term plug-n-play means.
You can rip out the old ECU, stick the new one in, and it works.
Now if you change half a dozen parts then your no longer just pulling out/replacing a ECU.
No ECU simply 'works' by plugging it in. There is no way it knows what AFMs, Injectors etc are being used.
Yeah, i was really after the easiest option, not the cheapest. After blowing 20k on the car in the last 6 months i'm not really looking to save 50 bucks :down:
either that, or get a mate with a 4x4 or something decent to tow you there via rope. THat is legal isn't it?
How far away is the tuning shop?
In vic that isnt legal, must be on a tow truck or trailer.
ill informed once again..ha thanks ash
i thought i could save money on installation costs for a pfc tune. i was quoted $500-$600 for an install and tune. i had been told tuning is $150 per hr and it would take on average 2 hrs to tune so if i could save $200-$300 just for installation all the better.
sorry for the hi-jack if any.
flat tow is the cheapest option, just be carefull with the tow rope and your front bar...or you could just take the front bar off? is that still legal?
I actually rang up vic roads about 12 months ago and was told the flat towing was illegal, after R31Nismoid post i checked the vic roads web site and it says it is legal....
I've done it many times years ago when i have a ZJ Fairlane, i was the "tow car of choice" for the boys cause it was a V8 etc.
Altough, it cant be done @ night, or with a car that doesnt have working hazards/brakes and so on from what i was told by the law.
But then they can also be wrong too
Installation of a PFC takes 30 seconds... or were you talking about other parts also?
You should be right taking the front bar off to flat tow as its the rear of the car (hazards, brake lights and so on) that need to be working.
Having said that, it might be illegal, but even a nasty officer wouldnt get too picky on that i reckon. Its pretty line-ball.
http://www.vicroads.vic.gov.au/Home/Regist...eredVehicle.htm
According to that link the only conditions for flat towing is the brakes must work, the cars have to be no more than 4metres apart and have a flag on the rope between the cars, with the price of trailer hire or a tow truck i know i wouldnt bother flat towing anything.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
