Because heat soak from engine bay heat causes the engine to lose power
with a podfilter.
There's a dyno chart on the internet somewhere (I think was done in Australia)
showing the differences with bonnet up, down and with a coldairbox, etc.
Engine gains 8 rwkw with bonnet up but when bonnet is down, engine power
drops due to heat soak (hot air from radiator, etc).
Some say this only happens when car is stationary like on a dyno. When a
car is moving, alot of air is entering engine bay.The result is the engine bay
cools down and water temps drop, etc. Basically a dyno fan is not producing
enough air to properly simulate real world driving conditions.
I guess can understand why ECU tuners take cars for a drive after dyno
tune, so to check that the tune is correct for real world driving conditions.
Another interesting thing I have found is water can enter between bonnet,
fender and wet the podfilter (enter the intake piping, engine). With a cold
air box fed by a intake pipe, this can be reduced.
I can see why they put a airfilter in a airbox at factory, because it keeps
the incoming air away from engine bay heat and water cannot enter
intake piping, engine.
Edited by SKYPER
  • Replies 62
i'd be getting the intercooler from the reasons limpus said and also if u get the ecu u'll have to get it tuned b4 the fmic and after again i take it, soo just a waste of money.. and i do think the fmic makes the car a little laggier but it picks up more top end imo..
Adding a intercooler is going to lean out the A/F (Air/Fuel) ratio
which creates more heat in the cylinders on top of the intake,
exhaust mods that have already leaned out the A/F ratio and
created more heat.
Basically raising the boost level with intake, exhaust, intercooler,
leans out the A/F ratio and is why a engine produces more power.
The extra heat inside the cylinders is then transfered to the
water running through the engine block and oil that lubricates
the engine. Basically water and oil temps are going to rise.
This is not good if your cars engine shares water and
oil with turbo.
With ECU your adjusting how much fuel is injected thus
can help to stop the engine leaning out too much with
intake and exhaust mods. Basically helps to keep
cylinder temps under control.
Edited by SKYPER
Adding an intercooler is going to lean out the A/F (Air/Fuel) ratio
which creates more heat in the cylinder on top of the intake and
exhaust mods that have already leaned out the A/F ratio.
dude are u serious?
stock ecu+mods= rich as a mother.
im pushing constant 11's A/F.
i hit R&R at 10psi
Edited by r33cruiser
Can i ask why people are anti POD filter? I have the HKS Spoung Air Filter with no Box... why would that be a bad thing?
Because they dont offer a performance gain at all.
Infact they can make the car slower
created more heat.
Errrrrm....yeah right...as if a fmic is going to lean the AFRs out too much...
When i got my car 2 years ago it already came with a catback...and the i actually went fmic before any other mods solely because its more of a support/safety mod before i went to any power mods...especially with the blistering summer temps now i think its a good idea...
This is a good idea and one reason why I was considering getting a FMIC, but then you have to remember that it would block some flow to the radiator = higher water temps, which is never a good thing in the middle of summer. Personally I'd just go the r34 cooler if you just want to keep the intake temps lower during the summer heat.
i thought if u wanted to run 11-12psi on the standard turbo you would need to upgrade the intercooler anyway?
having said that you'd prob want an ecu @ this boost level.
so fmic+ecu = ftw
If at 100% throttle constantly like on a racetrack, then yes you
need a front mount intercooler. Also a steel wheel turbo upgrade.
On the road, supposedly can get away with 20 second burst's with
stock sidemount intercooler on a R33. A sightly larger R34GTT
sidemount intercooler that's installed in a R32 GTS -T is said
to be ok for couple of laps on a racetrack.
I read that 13.5psi is the max boost for R32 intercooler. Isn't
a coincidence that max boost on the stock R32, R33 boost gauge
translates to roughly the same 13.5psi?? R34 GTT stock boost
gauge roughly translates to around 14psi.
Stock R32 GTS-T intercooler has been proven to be capable of around
211.3rwkw on a dyno at I think was 9.33psi with a RB25DET conversion
in a R32 GTS-T.
Here's the dynochart -
http://img512.imageshack.us/my.php?image=dsc0725xw5.jpg
Also add a bigger fuelpump to the ECU, intercooler upgrades.
Edited by SKYPER
FMIC is there to stop detonation when running more psi + add more cooler air then a stock unit can cool
but a intercooler does add more power by it self....... compared to not running one at all, all those jap turbo cars that dont run intercoolers, kei cars, dihastu charade etc. air coming in would be warmer then a intercooled engine, warmer air means theres less air getting to the engine, as warm air expands, then when the air is colder.
thus more air = more power
Geez Dan_J, my head is starting to hurt.
The above statement is completly wrong. Your proof is Kei cars and Dihastu's are slow (because they don't have intercoolers)?!?! It might also have to do with the fact that the are 3 bangers with turbos about the size of your fist that run .4 bar and aren't made for performance.
I think you guys are confusing whether or not intercoolers work period compared to if the make more power by just slapping a bigger one on a car when it already had a smaller one. On a stock car where you are not already overwhelming the SMIC, THE AIR WILL NOT BE ANY COLDER, IT WILL JUST TAKE IT LONGER TO NOT COOL THE AIR AS EFFICIENTLY!! (takes longer to heatsoak, and you can almost instantly heat soak a factory SMIC with 400+hp).
Now here is one theoretical that might half way support your notion. You have a pretty stock (bolt on) car that you are already running .9 bar on which is heating the air up pretty good through that stock turbo (already tuned). You can add a FMIC and IF YOU RETUNE IT to take advantage of the fact that you can now run more timing, you could gain a few ponies.
Also, saying x amount of boost can be supported by x intercooler is dumb. As with the same misconception about how much a stock headgasket can take, it has to do with hp, not boost, and also where you are in the turbo's efficiency map. A stock RB20 turbo @ 1.2 bar is doing nothing but pushing hot air. Even if it wouldn't blow up, you won't gain anything. Now a T88 @ .8 bar makes (I'm guessing) over 600hp. Do you think a SMIC would support that? No way. Also, could a SMIC even flow enough air with out being a HUGE restriction to make 600hp? No way.
Hmmm.....
I went from an Apexi Pod Filter (CAI with heat shield) and full 3 inch exhaust, and then solely added a GReddy V-Spec FMIC with no furthering mods - lag seemed less, and car "felt" like it pulled alot harder (running standard boost). No stats to back it up, just the feeling after driving the car for four years prior....??
Maybe it's the fact I have a large shiny thing hanging down the front now?? :D
Edited by Peter
If your not planning on upgrading the turbo, get the R34 GTT SMIC. It is bigger and rated to handle more power and it bolts into the same position as your present one, so you will be able to install it yourself. Saves the hassle of trying to fit and mount a FMIC and $$$$. If u want more info on installing the R34 SMIC pm me, or there may already be a post of how to do the upgrade. Its rated for like 200+ rwkw so unless your gunna upgrade ur turbo you dont need a FM. Cheaper to buy and relativley easy to install...
My comments are from other peoples experiences, experiments, comments on stock intercooler,
etc and from my own reasearch into stock and upgraded intercoolers, etc and their
applications.
Well...in your research have you tried it for yourself? an fmic does add more power if not for the fact that the charge air is cooler and denser then also because it flows better than the restrictve stock smic...
Even on a stockish car there would be a slight increase in performace with the addition of just an fmic...and without even touching the boost...
On a side note...alex r33s2gts25t...i could be wrong but doesn't a r34 smic need some modifications to the inlet/outlets for it to fit? I remember reading somewhere that it was the case with fitting to r32s but it might not be the case for r33s...
Edited by limpus
Nah on the R33 the bolts line up perfectly... the hardest part is getting the front bumper off lol... the only thing that becomes a tight fit after u put the r34 one on is the wheel guard... but its flexible nd plastic.. so i just cable tied it back to its original holes at the base of the bumper because they wouldnt quite reach... its pretty much just a swap job
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
