  • Replies 268
yeah the cars handle much more realistically now. they don't corner like they're on rails any more, there is body roll too, and you can break glass on cars now too and they have very realistic damage. burnouts are available and also fun. yes you can shoot people, blow them up whatever.
my only criticism so far is that driving is too much towards simulation and too far from arcade style. it's really hard now to hand brake turn without loosing lots of speed, or spining into somthing. that was part of the fun of the old ones. just hop in a car and hoon off.
Sounds the GTA 4 ad adopted DRIVER car handling characteristics
Fantastic Game.. Im a bit dissappointed in some of the bugs ive Had to encounter. I really shouldnt be Restarting the Game 3 times. althought i was playing for 4 hours straight..Multiplayer was a load of Fun while It lasted for a good hour, Until the Gaming Servers where Overloaded, And no one could play.. have to say so far this game is a 9.825/10 for me.
I must add the Realisim of Doing Stand still's Is bloody impressive, didnt think so much smoke would pour out.
Try it now. Ill be surprised if its working.. It appears their is a big Controversy goin on, just checked the net. It appears loads and loads of ppl are having glitching and freezing problems. and No one can connect to Multiplayer game servers.
Rockstargames = FAIL!
yeah im loving the gps system too, great when your drinkiing :spank:
id have to agree about the cars though, you cant brake very well if you are turning and the handbrake is a mofo to control. hopefully ill get used to it
at roughly 14% now
word! brake and then turn = un saveable understeer! and handbrake and turn = massive slide and mostly a spin or huge loss of speed/time. yeah hopefully I will get used to it, but for the moment I'm crap at driving in GTA.
Gazzila, can't try it atm but I will do later on. hope they get it sorted asap. :yes:
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
