  • Replies 268
yeah the cars handle much more realistically now. they don't corner like they're on rails any more, there is body roll too, and you can break glass on cars now too and they have very realistic damage. burnouts are available and also fun. yes you can shoot people, blow them up whatever.
my only criticism so far is that driving is too much towards simulation and too far from arcade style. it's really hard now to hand brake turn without loosing lots of speed, or spining into somthing. that was part of the fun of the old ones. just hop in a car and hoon off.
Sounds the GTA 4 ad adopted DRIVER car handling characteristics
Fantastic Game.. Im a bit dissappointed in some of the bugs ive Had to encounter. I really shouldnt be Restarting the Game 3 times. althought i was playing for 4 hours straight..Multiplayer was a load of Fun while It lasted for a good hour, Until the Gaming Servers where Overloaded, And no one could play.. have to say so far this game is a 9.825/10 for me.
I must add the Realisim of Doing Stand still's Is bloody impressive, didnt think so much smoke would pour out.
Try it now. Ill be surprised if its working.. It appears their is a big Controversy goin on, just checked the net. It appears loads and loads of ppl are having glitching and freezing problems. and No one can connect to Multiplayer game servers.
Rockstargames = FAIL!
yeah im loving the gps system too, great when your drinkiing :spank:
id have to agree about the cars though, you cant brake very well if you are turning and the handbrake is a mofo to control. hopefully ill get used to it
at roughly 14% now
word! brake and then turn = un saveable understeer! and handbrake and turn = massive slide and mostly a spin or huge loss of speed/time. yeah hopefully I will get used to it, but for the moment I'm crap at driving in GTA.
Gazzila, can't try it atm but I will do later on. hope they get it sorted asap. :yes:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
