played it last night and its awesome...cant wait til uni finishes tonight so i can head home and play it again til early hours ofthe morning...missus will tell me off again....oh well
  • Replies 268
GRRR God dammit!!
Thank you for contacting Play-Asia.com.
We regret that we are unable to provide an estimate time frame when we can ship out 'GTA IV' at the moment as this is really depending on the stock level which our suppliers could provide us. Please no worry, we will make sure to ship out this order immediately once stocked. Thanks for your patience.
If you have any further questions, please do not hesitate to ask.
Best regards,
Bryan
Play-Asia.com
Dont worry? Of course I know that you will ship it when it's stocked. WHEN THE f**k IS THAT!? :rofl:
GRRR God dammit!!
On the play-asia site it says they will be recieving the pre-orders tomorrow and shipped out. So considering it takes time we should recieve it no earlier than late next week or the following week.
yeah? hmm I'll have to pay attention again, but I swear it said 720p.
Yeah its weird, call of duty does it aswell.
In the settings menu on the PS3 where you set the video settings (720,1080i,1080p), if you have all three selected it automatically plays on 720. However if you deselect 720, it will play on 1080p. I wonder why it does this :rofl:
Doing a burnout for a while blows your tyres!!! Fantastic :)
Yeah they're site says that, but this guys answer doesnt sound promising:
"We regret that we are unable to provide an estimate time frame when we can ship out 'GTA IV' at the moment"
so the only thing to be cut was... an anal raping scene? lol
so, how cheap is play asia compared to buying it from a retailer her in Aus?
Theres a few other things.. Nipples censored, blood doesnt pool on the ground etc etc
Its not that much cheaper than BigW who had it for $78 or something. It's $70AUD on Playasia. The only reason that I ordered from playasia instead was that I didnt expect it to come out at such a low price in Oz! Most big PS3 games are $100+
Yeah I ended up paying $73.00 AUD including delivery. Kinda sucks now I hear BigW is selling it for $78.
Ohwell thats life.
For anyone who has not yet bought the game
http://www.bigw.com.au/entertainment/gta4....?promocode=BIGW
Edited by LatinR33
in the o/s edition when you pick up hookers you can pick between 3 "services" which are then played out in front of you in full view! in the aus version you pick them up and jus see the bumper bounce up and down.
Ohwell thats life.
thats what i was afraid of
$30 bucks in my poket is still $30 bucks in MY pocket
no fkn wai...
definately need to be a part of that
thanks for the response guys
Edited by ctjet
well this should explain my resolution question. and why mine defaults to 720p. pinched from another forum:
"There are 3 types of HD games on the PS3.
Games that are 720p native (will not run at higher resolutions).
Games that are 1080p native (will run at 720p, 1080i & 1080p).
And games that support 720p & 1080i.
You can't force or "trick" a game to run at 1080p if it doesn't support it. What you are doing is getting it to run at 1080i, then the PS3 is outputting the signal progressive. The reason games that support 720p and 1080i default to 720p is that 720p outputs at 60 frames-per-second, and 1080i is half that (30 fps). Visual detail on a moving image is about the same for both resolutions (1080i is twice as many pixels, half as fast) but the higher frame rate is better for gaming. So when you try and force a game to 1080p you are actually getting a lower frame rate, and no increase in quality.
The reason they put 1080i support in games is that some older HD sets do not have 720p (they are 1080i only for HD), and on those sets a 720 only game ends up running at 480p SD resolution (Sony never enabled full hardware scaling for HD games). The game knows the best resolution to run at, so don't waste your time trying to "trick" it because you can't get 1080p out of a game that doesn't support it. Games that have true 1080p support will run at 1080p. If the game picks something else then that is the best resolution for the game.
NOTE: COD4 is a special case because it does "support" 1080p output, but it is not rendered at 1080p. COD4 has software scaling built-in to the game engine. It is actually rendered at 600p and scaled to whatever resolution your TV requires, so the game is not really a 1080p game."
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
