It sounds like you were trying to pick a fight GTST, you definitely took what he said the wrong way - it was quite valid for its intended purpose. There's no need to get so angry about it either, I mean it was directed at me and even though it wasn't really applicable to my situation (as I explained later), do you see me spraying him over it? Ease off the juice man...
Why would a noob or a person with an injury (or recovering from an injury) need to do front raises?
what does this achieve?
nothing.
it's an exercise which does NOT build muscle or strength or have any positive effect on recovery/rehab.
It might be used by some pro in a video he puts out or prior to his contest.
Birds - I'm not trying to pick a fight.
I'm trying to stop people giving shit advice.
nothing.
Sounds to me like you're the only one peddling shit advice here.
A perfect example of injury is a damaged rotator cuff, a person may look to strengthen all muscle around the shoulder to prevent further injury - like myself
A noob who is looking to improve shoulder muscle may incorporate it along with other shoulder exercises like Lat raises, dubbell shoulder press etc etc.
For rehab and n00bs, light weights will make you stronger.
You won't be strong in the relative sense of the word (i.e you will still be considered weak), but you will get stronger than you were before.
If you are fit and healthy, the general rule is, go heavy compounds for size and strength. I think we can all agree on that one.
the delts are a circular group of muscles... front, side and rear... to properly work them and get good defination for a physique comp... you need to attend to those areas...
now lets put in a real world situation... ehhh... your helping your mate move... you bend down... pick up a box... carry it out to the truck... extend your arms and place it on the tray which is at chest height.... now youve just effectively used your front delts through that entire process... you havent had to press the box over your head... you havent had to push the box away from your chest...
so why are front delt raises so bad?? we need strong delts to help us do normal things in life... like lift a coffee cup... pick things up.. etc etc..
Agreed.
Hey guys,
im looking to put on some more size so ive worked out my new diet and split routines etc
Just wondering on how "heavy" to go for each set?
I was planning on the whole 1rep max method eg 1rep max 100kg bench will equate to me doing:
1 warmup set of 10 reps @50kg
1 semi work set of 8 reps @60kg
1 work set of 8 reps @70kg
1 work set of 8 reps @80kg
Providing i can do these with perfect form etc is this effective or should i be warming up/working heavier?
Hey guys,
You want to go as heavy as you can while maintaining good form until your final rep of the last set for the desired rep range. A good balance between size and strength gains will lie between 5-10 reps so for size id be sticking between 6-8 reps per set but once again everyone reacts differently.
If my working set for flat bench was 80 id be doing
wu
40x10
50x5
60x5
70x3
75x1
working
80x6-8 x3
adding 2.5kg to the working set each week and adjusting the wu's appropriately as your working sets get heavier
youve gotta do the right workout for your body type... when you ask such a broad question.. you can consider the answers given, but dont use them as gospel as everyone is different..
some people work better with drop sets (start heavy and back off the weight, keeping the same rep range), some people work better going up in weight... some people can do 10 working sets... some people only need 2 working sets... etc. etc.
if you're a hard gainer.. doing lots of sets and lots of reps is going to make you go backwards..
basic rule is if you cannot lift the same or more in a movement as you did last workout... your body has not had time to recuperate. (spell check?).. so go back to bed... chow down some food, repair yourself, leave that body part until its all good.. otherwise your just doing more damage.. unless your going for a bodybuilding style month on month off workout... where they work one body part per month.. but these guys repair themselves 5 times quicker than a normal human person.
It's probably not a bad idea to get at least one session with a qualified PT who knows what he's doing. I consider it pretty essential that you find out what muscular imbalances you have (i.e. weaknesses) so you can focus on those parts, before going headlong into trying to gain tons of mass without knowing if your technique is correct or if you're pushing too hard on a particular group or neglecting another. You'll end up injuring yourself in the short term through improper technique, or longer term through worsening imbalances.
A PT can also watch what you're doing from a 1st person perspective whereas we can only give you whatever experience we have in writing. You don't need to continue with multiple sessions / wk etc, just one or two to begin with, so he can monitor what you're doing and give you advice / programs for what you should be focusing on in the immediate term.
For example I'm aware that I need to focus more on my back (lats, rear delts, etc) and core with less emphasis on my chest, as I have traditionally focused too much on the chest when I was younger.
Hey guys,
since this highlighted part is what will put on the size, tell us what it is.
how tall are you?
what do you weigh?
and what does this diet consist of?
I'm with the people who say don't take the advice here as gospel, and don't ask for a designer workout plan...I mean, we don't even know if you're doing the exercises properly for starters...
Everyone is different, too many variables involved even if we asked all the right questions. Find a body type you like and adopt what that person is doing / get them to teach you how they do it. And do this with the knowledge that you will get to look similar, but not exactly the same as them because of all the variables involved.
Im around 5'7",
Started off at a scrawny 65kg and currently weigh 72kg with little fat but nothing major.
Ive spread my diet over 6 meals for a total of 2,484 cals and using the 40/40/20 ratio total 211gm protein, 239gm carbs and 65gm fat. All this comes from lean meats, complex carbs and protein shake.
ok.
in short
with your goals being to get bigger..
1.) 2400 calories is not enough
2.) your PCF breakdown is all wrong. you have WAY too many carbs, nowhere near enough fats and protein should be about 100g more per day at least.
who created that diet structure for you?
ok.
in short
err..i agree the total caloric intake is lower than it should be but 40/40/20 pcf is fine as macronutrient breakdown, its nothing new
this. a lot of people follow a 40/40/20 split. you can easily gain muscle with this..
also to YDURTY4, perhaps lift your calories to 3000 or so. if you start gaining too much fat lower it
Edited by gersfan
Yea might have to,
i'll stick to this for roughly 8 weeks and assess the results then. Been lifting for 2yrs now and i understand the whole slow and steady wins the race concept as opposed to those who use gear, apparently having great "genes"
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
