Have you tried more explosive exercises like jump squats, squat presses/snatches etc?
yerrr... i do that stuff during the summer months when its nice to be outside.. and capoeira aswell.. so lots and lots of lunges and jumps... lots more plyometrics and lots less weights.
  • 4 weeks later...
Ok finally back into the gym again now (3 weeks running).
Fk im weak :D
EG: Bi curls I'm only managing 10KG 3 sets x 10 :)
I can't even do 2 dips lol
Gonna be a long 3 months to get back into even basic level of form.
At least I still have reasonable chest strength, although it's only machine at the moment till i get some reasonable base and then move back over to free.
Gday kunce,
My missus said to me the other day that she wants that buff bodied man that she had before marriage back. Seeing as we've been married for 10 years there pretty much no fucking chance Ill be able to find this dood so it looks like its up to me. I dont need to lose much weight nor put too much bulk on (cause im sxc as it is). I am planning on buying a home gym (weider is on sale atm), a rowing machine and a trainer for my pushie. Ill grab a straight bar and some dumbells too.
So,
I need advice on said home gym
Advice on a routine to suit
Thanks in advance bum monkeys.
Soon you'll be benching the 31 for a warmup.
lol RB26's, one arm each :ermm:
It's weird my BI's have lost massive strength, yet my Tri's (pushdowns) im almost doing the entire stack... However much that weighs.
Yet can't do dips as everything else is failing :ninja:
Same for legs, still good strength there interestingly
Yeah I know the feeling, and I only did 3 weeks away from the gym :ermm:
You should buy 2 build RB26's, remove sump, hand through bottom of block, and hold that crank like a dumbbell.
I've never been any good with the biceps :D even after the 3 weeks though I can still do 3x10 reps of dips with +15kg :ninja:
Gday kunce,
So,
<cut>
So what are your goals?
It sounds like you want to get a little fitter, and maybe lose some weight. Gaining muscle / losing weight is mostly diet.
Routine wise they're are a lot of things you could do, if your aiming for strength I'd recommend bench, deadlift, squat, military press , dips or similar.
Powerclean's are also great but they are a little technical, you also either need bumper plates or quiet a few mats on the floor to take the impact of the cheaper plates.
That's because you don't really use your biceps that much :ermm:
I found that legs maintain ok, shoulder / upper back strength you tend to lose quite quickly as well :D
lol RB26's, one arm each :banana:
Yet can't do dips as everything else is failing :P
use the assisted dip machine.
you're probably not isolating the triceps when you do the dips.
Anyone able to help me source the following in pill forms?
Ephedrine HCL
Caffeine (No DOZ id assume)
Potent Yohimbe
Am basically looking to make my own pre workout/thermo stack seen as hydroxy etc are a joke these days since the magical ingredient was banned. Thought id check with the pros before i went into a chemist or health store asking for these products and they look at me as if im trying to cook some gear lol.
Lol bananas,
so far ive found horny goat weed should substitute for Yohimbe cos it basically just boosts testosterone and energy. Ephedrine not sure as yet, but this is all legal as they can be found in Nutrex Lipo 6 which is on sale on shelves. I just dont want to cough up $70 per month for the stuff.
Just a standard ECY stack really, not a lot wrong with it.
Not really 'cooked' as such, plenty of information on the net for amounts to use etc.
You mean the tri-PD's? I have my shoulders locked and use abs to support me :)
I make sure i use nothing more than isolated tri's for those.
I'll give the dips a crack next week as i upped all the chest/tri & shoulder weights this week and am rather tender today.
Two more sessions @ this rate and i'll have a crack @ 5 unassisted dips on Monday :P
No I mean the dips.
you're prolly using your chest too much and your lower pecs are not strong enough.
If you can almost push down a whole commercial tricep pushdown weight stack then dips should be easy enough.
Ephedrine HCL
Potent Yohimbe
Been looking for Ephedrine for a while as well as Yohimbe, illegal & super hard to get a hold off
Caffeine is simple.. Most supp stores stock it.. ASN for example.. or you can order of BB.com ... I ordered 4x 100pill (200mg) bottles About $8aus each.. Great stuff to stack against your pre wo supps.. :P
Edited by Tomek
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
