id get an adjustable bench so you can do incline and or decline.
dips are a good idea as well. would also be interested to see their pulley system as it could be worth a look at.
quality and price i dont know about.
I would be inclined not to listen to what the side of a protein container says about serving sizes...
of course they are goin to say "take 3 scoops" 3 times a day. They are trying to sell the crap.
figure out how much protein u need a day, usually 1 gram for every pound of body weight (kg x2.2) then use the protein to fill in the gaps between meals, thats why its a "supplement"
Theres no use having a 100 grams of protein in one hit, it needs to spread out through the day
Good point. As with any information you have to consider the source!
I've found 2 scoops of Torrent is enough for me, not the 3 prescribed, especially as I often take Vitargo during the session, so that'd be way too many carbs when taken together.
god damned OS trips... just got back from Thailand for a friends wedding... 10 days spent drinking and eating nonstop and I feel like garbage... fat garbage... just a note, flopping around in a pool/ocean cannot possibly burn off 8 litres of booze and enough Pad Thai to feed every starving child in Africa...
f**k you Ectos...;)
grass is always greener hey... hate having to eat like a medieval orphan but at the same time like it when people stop what they're doing to watch you lift
goal for this year is to have both... look and feel lean while lifting enough iron to affect the earths gravitational pull... after 6 weeks of good work I've fallen off the tracks... weaksauce... time to put down the beer and open a can of harden the f**k up
because your body digests x amount of protein per hour regardless of how much you give it.
So you prefer to load a ton of protein in one meal, and piss out 80% of it instead?? It's not hard to space your protein out over the course of the day.
Why wouldn't you take a slow release protein source before bed? Your catabolic period overnight must be quite significant closedeyes.gif
...I see no logic here
Yea i have no idea what his argument is
anyone here tried doing slow reps? get the set to last near 70seconds. I have been giving it a go and cannot lift near the same amount of weight.
example is for bench 3seconds down, at at the bottom and 1 second up.
recommend giving it a go for a change.
I find slow reps or negatives are both good if you've got a minor injury or are feeling flat and can't push a heavier weight; you can still get an awesome workout while also changing it up a bit and keep the body guessing.
On the protein argument I've also read that those of us who take a lot of additional protein need to make sure we are getting plenty of calcium intake (i.e. through milk, or other sources, in other words check your protein supplement to make sure there is calcium in there as well). This is because the body uses calcium for protein synthesis. You don't want a calcium deficiency.
I never said I loaded up on protein... no shit it isn't hard to space it out over the day, I just said you didn't have to. You don't piss out protein...
Why wouldn't I take "slow release" protein before bed? I dunno maybe the fact that by the time I goto fkn bed I've already hit my protein macros for the day so there's a shitload that will be released over the night.
Dude I suggest you do some research before posting...
"When a high dietary protein intake is consumed, there is an increase in urea excretion, which suggests that amino acid oxidation is increased.."
It depends on the types of protein you're consuming, unless you've been consuming a lot of slow-release proteins throughout the day, your overnight release won't last nearly as long as consuming something like casein before bed (4-6 hours release).
In response to slow reps, I always lower the weight slowly, and explode on the way up. Muscle fibres tear on the eccentric phase (shortening phase), so for example lowering the weight during a bicep curl is more important than raising it.
While on this topic, has anyone here gotten a friend to push down (encourage the negative phase of the lift) on a bar, etc. while you try to resist? It's like super negatives lol, crazy hypertrophy results
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
