You guys should get your BF % checked too, baseline and post-gain, after serious gains like that. Very easy to gains in fat for gains in muscle, that you won't be able to visually see.
I've definitely decided I don't like what needs to be done for bulking...still finding it stupidly difficult to manage eating more than just lunch while at work, it's at the point where I'm gonna find another desk job. I'm done with never being behind a PC where I can eat WHILE WORKING.
So for now I'm cooking bulk chicken breast (the slightly spiced shit from Lennards just now), broccoli, and brown rice (with a dash of soy sauce). Shit tastes amazing, so I'm going to eat as much of this as I can and see how slow lean gains come.
f**k my job. Lucky the pay isn't terrible...
So another few weeks have passed and another couple of kilos down... starting to get too skinny for my liking so i may start goin in the other direction again...
Call me a f**k head if u like but i like being big and and intimidating. A certain confidence comes with knowing you can look big.. even if theres a bit of fat under that shirt :D
anyway relults speak for themselves, im sure anyone can acheive what ive done with a bit of discipline in regaurds to training and diet. I could have definatly spend more time doing cardio but its boring as hell so i mainly focuesed on weights.
Let me know what yas think
left to right 96kg, 92kg, 91kg, 88kg
cheers
cheers
I reckon the 3rd pic is the best size.
You are a f**khead and you look best at the last size ;)
If it makes you happy go for what you want, that's all that matters in the end. But I'm from the party of people who will say you should stay where you are and try to put on lean muscle instead. As hard as it is to do that, let the muscle be your extra weight - then you can have your cake (well not really) and eat it too. If not for the appearance, then for the health benefits. Have your running times improved with the weight drop? Congrats on the achievement by the way - I too find it easy to change weight, but for a lot of people this is the hardest thing in the world.
I know what you mean about the weight giving you extra confidence, even if it's fat. I felt the same way at 89kg, it was about the only advantage to having fat on me. But I much prefer the definition of 80kg and I think you look best in your third pic simply cause of the lower BF. You have outline on your abs now!!! A bit more muscle on your upper chest and you'd be set! :)
Haha f**k off my chest is fine! Na your probabaly right, need to work on my shoulders too.
Running is pretty good, feeling very light and I don't have any soreness in my shins or joints which I'm really enjoying. Actually starting to enjoy it a bit
Thanks for your input birds. As valuable as ever :D
Might have to work on that tan too hey ;)
that's what I thought too.
not saying it can't be done.. I'm saying you won't be saying "putting on weight and losing it is easy as shit" when past 30
It's not just age related, it's also what happens in peoples lives in their 30's...
You'll see what I mean.
It's just not as "easy as shit"
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
