Cheers. Well, up until recently I had a BMI of 17. I've been put on anti-depressants and I have started putting on weight, but it's all fat. I have very low testosterone, which my endocrinologist attributes to my wight being so low, which makes it hard to put on any muscle. I've also been told that I shouldn't be doing any high impact exercise, and I just thought creatine may help.
White GTST - if you are referring to lexapro as your medication then you "should" be ok. a lot of the pre workout supplements such as NO Xplode to contain creatine aswell, however high doses of caffeine does not do well with lexapro, so please stay away from the pre workout supplements with creatine in them.
Edited by 25GTT
I don't get why BMI is still used.
Such a waste of time.
Anyway, back to your low test levels.
Are you suitable for TRT?
A friend of mine use to be about 80kg.
Was always obsessed with getting cut and lower fat percentage etc.
Months go by and no one hears from him.
Checks in to a forum we use to frequent and starts a "hey guys i've got an issue" thread.
posts a photo of his current self.
42kg skin and bones.
Anyway, months and months of trying to eat more, he sees a doc, his test levels are non existent.
Basically he broke himself.
Anyway, doc started him on some oral tablet to stabilise his hormones.
Not TRT but something.
Fast forward a year and he is 100kg and well in to powerlifting.
Important part is to see if you can get some meds.
I was in a similar situation. I went into the endocrinologist's office expecting to be started on TRT but after he weighed me at 55kg he told me not to come back until I was at least 60kg. I'm nearly there now and my next appointment is in 4 weeks so I guess I'll just have to wait and see.
How tall are you man? BMI of 17 at 55kg i'm assuming you're pretty tall. There's nothing wrong with supplementing creatine into your diet; it works for some people but not for others so the best advice anyone can give you is to try it for yourself
What are your goals Tim? That's the first place to start when giving you advice.
Are you trying to get faster at swimming? Trying to gain lean muscle? Just gain weight in general? Powerlift? Bodybuild?
Basically i'm just trying to get my life sorted and get fit an healthy again. I obviously need to put on weight but i'm struggling to come to terms with the fat i've put on, which I attribute mostly to my meds. It would be nice to put on some extra muscle but without doing resistance training, which i have been advised against, and my very low T levels I guess it's just wishful thinking.
body weight training if you cant use heavier plates
don't waste your time with sit ups. if you wanna hit your core/abs hard try hanging pike.
push ups, pull/chin ups, dips etc you'd be surprised at how many different workouts you can do using nothing but your body weight
you should also try different forms for every one of em, there are a million different ways you can do a push up...
I know people who have naturally low testosterone and supplement it with prescription drugs like testogel - they have seen good results from this.
Situps are great, I owe my abs to them. But you have to do them properly (they are one of the most difficult exercises to do strictly) and have low enough body fat to see the results.
I'm confident that I will be started on the TRT at my next appointment. We spoke about it at my last visit and he said If I was to start I would would be given the rub in gel. Unfortunately, the first place the weight gain was visible was around my mid section, so my abs are now less pronounced. But I know it's for the best.
dude your 55kg... forget about seeing your abs and just get healthy/strong first... you almost sound like someone with an eating disorder... hours of plodding up and down a pool aren't going to help you put on muscle either... swimming is great for rehab but for getting stronger you need to work in some resistance training... not saying don't swim, as its great but mix it up a bit
seriously, your taller than me but only a couple of kg heavier than my wife... and she's super petite!
nobody recommended any of those lifts... the only suggestion was some body weight stuff
but yeah... internet forums are never a good place to get your medical advice
a little off topic but here's something to discuss: should athletes be granted exemptions to use TRT if diagnosed with low testosterone by a doctor? considering the use of T is illegal in most sports...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
