hey gays, im looking at buying one of these protein shake powders, and im wondering which is best for me???
i dont go to the gym, i just want to take something in the morning before work, my job has manual labor in it which helps???.
im just looking to put on a few kilos since im a bit to skinny for my liking.
chars!
[quote name=ClutchBurndout-:(' timestamp='1337759708' post='6367901]
chars!
Try vanilla mansplurge... apparently it boosts your natural test levels and get you huge really quickly
If you're not trolling and actually want to put on a few kilos...and be aware that without proper exercise (manual labor is not enough), it will be just fat...then overeat the shit out of yourself and drink Ultimate Nutrition's Xtreme ISO Mass Gainer twice a day.
On a side note, I've been taking the Ultimate Nutrition mass gainer again, for the last 2 or so months. I was weary about getting back onto it after all the fat I gained last time. But I've cut down the serving sizes and I'm mixing it with water instead of milk (tastes awesome!). Also not stuffing my face with food left right and centre to try and gain weight. Consequently, my weight has stayed the same (+/- 1kg) this time around, but my bench hasn't been this strong for 2 years. I'm ecstatic. I was stuck on a plateau that I just couldn't break through and it even depressed me that I couldn't lift what I used to. Now looking forward to some new personal bests and a little more muscle :)
who thought i was trolling?
Ultimate Nutrition's Xtreme ISO Mass Gainer sounds expensive, something with that name cant be cheap lol
Edited by ClutchBurndout-:(
Which gainer mate? I'm back on the UN Muscle Juice Revolution due to lately being relatively strapped for time in every aspect of my life lol....I'm finding it fine once more, will see what gains I make this time. Did honestly notice very acceptable gains last time (when compared to not taking it). It's great with water (though personally makes me feel very bloated with milk), and it has fark all sugar compared to the "non-revolution" version (70% less :yucky:).
Comes in at $110 for 5kg retail from my local store, which is only a touch more than A1 supplements after delivery. Just snag a free shaker or something hahaha
Pretty cost effective. ~$120 for 4.5kg and that lasts me about 2-3 months.
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
