especially as I've seen programs that get very specific, 77% 83% or whatever
What the hell kind of programs would tell you to work at 77% or 83% of your 1RM.. this is a great example of powerlifting/bodybuilding bro-science at it's finest. Your body isn't going to adapt to an exact percentage. You might as well work off of 80% because that extra 3% either way won't make a noticeable difference in strength or size gains.
For me, crafting the body into something most desirable for the opposite sex, is where it's at ;)
hahaha I guess I'm different due to being married... but for me it's about being allowed to keep my man card... I'm a graphic designer which apparently means I have to weigh 60kg, wear thick rimmed glasses, girls jeans and be into bicycles... fck that, after spending all day discussing the differences between 2 almost identical fonts and drinking macchiatos I like to go to the gym and do badass shit... I'm no PL but I like to lift heavy... nothing better than chucking serious weight on an Oly bar, sitting it on the ground then lifting it above your head
I was doing dips yesterday with a couple of the 24kg kettlebells hanging off a belt looking like a couple of giant black balls swinging between my legs... I felt pretty baws for a few minutes lol
its funny when I meet someone for the first time they pretty much always assume I'm a tradie.... until I show them my girly hands lol
On lean gains he reckons for an intermediate lifter
1.6 x bw - squat
1.2 x bw - bench
2 x bw - deadlift
This is a good starting point, a minimum if your serious
just gotta sort out my squats :S... stupid weak legs
i like to read the Scivation Books stuff. Currently working on their Tri Phase routine (slightly modified but I will more then likely go back to the original).
They have books on just about everything that is training.
http://www.scivationbooks.com/
I like to read this site called
www.itsnotrocketscience.com
Listen to your body, train what works best for you
This lol. Too many people looking for the easiest/fastest way to gain the most amount of muscle in as little time as possible, which kind of works contrary to what is actually required at the gym - a f**kload of effort to get what you want.
its not so much looking for the fastest way to achieve results, well not for me anyway. I learnt years ago there is no fast way.
I read this stuff because I find it remotely interesting. I also dont think that I am perfect so I like to see and hear other people's opinion on a range of subjects. There are always better ways of doing things, its just a matter of hearing them out and deciding if you agree or not.
My 2cents.
My 2cents.
Without artificial assistance you mean Mitch? Seem to see a whole bunch of huge teenage blokes in the gyms these days, partly they're starting at an age where their T is at a peak, but mostly a whole lot of them would be on the gear.
Interesting article in the SMH not long ago; not really 'news' , but interesting nonetheless - the 'steroid vacation' to Thailand: http://www.smh.com.a...0526-1zblt.html
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
