TM7GTR: Will take the shoulder feedback on board - cheers.
Trozzle: The gym has a machine that you can use your legs separately or can be used pushing both legs together or each leg alternating. You load the free weights onto the machine for each leg. Can be used as a press but ensures each leg pushes the same amount: just not as declined as the normal press machine.
I mentioned I pushed out 140kg x5 freeweight squat a few posts ago ya big girl!
I don't want to offend Trozzle, but if you're not going to squat below parallel you may as well just stick to leg press.
From the last video you put up of your 120kg squats they were all high, so I'm pretty certain these 140's you claim will also be high..
Nah that's cool man, I had never had anyone with me to critique/correct my technique until I recorded that. Since then I have always done squats with my mate, and initially dropped the weight back to an easy 80kg then ensured that every squat was at least parallel from there on.
I don't go below parallel as when I do with anything over 100kg my left knee goes all weird and has a worrying ache immediately afterwards. Going to parallel with any weight feels perfectly fine though, so I do go parallel with 140kg
What's wrong with squatting to parallel?
Nothing, my comment was about the 120's which were higher that's all.
Hmm doesn't sound good :unsure:, well unless you address it I guess all you can do is work around it like you're doing :thumbsup:
Edited by GHOSTrun
It's undoubtedly nothing since I don't get anything similar when doing any variation of leg press, but yeah better safe than sorry.
There's nothing wrong, although some studies have shown that the full depth squats cause the knee joint to lubricate with synovial fluid more efficiently. I guess this way if you were to fail at parallel and drop beyond, the knee is well prepared rather than the muscles giving up completely at this "sticking point". The other issue would be reduced flexibility in the hip flexors.
On the flipside consider the possible injuries caused by the direction of force being applied to the joints when beyond parallel. The force is now no longer compressing the joint, it is in a small way attempting to separate it.
your calves and hams will prevent it from "separating" as you call it.
parallel or full squats is a huge argument not worth opening.
Especially since this is not about someone looking for 3 white lights after squatting to show it was below parallel and competition legal.
if you are to look at it from a "training" point of view, when doing bicep curls, do you curl the bar from your thighs up to mid point and call it a rep or do you curl till forearm and bicep meet?
squat to parallel will give your legs a workout, but if you have the flexibility (which with stretching and mobility work 99% of people without a birth defect or fused joint due to an operation could get) then squatting to full depth where your calves and hams prevent you from going any lower will build strength and muscles that half squats can't.
look at some old school photos of the greats squating.
Arnie
Dave Draper (Pic title says tom platz but it's not)
tom-platz-squat.jpg?w=400
Tom Platz (I'm sure you've seen his legs)
Anatoly Pisarenko (you may not know of him)
totally agree... however for some people it takes some serious practice to get that low correctly... not as easy as it looks!
the olympic lifters make it look so effortless... was watching the 48kg girls C&J 100kg+ above their heads... serious reality check for anyone who thinks they're strong
Everyone post their chest workouts. Mine is years overdue for a change, only problem is apart from bench (flat/incline/decline) and flys, there isn't a whole lot more that can be done.
Not that it's going to change anything body composition wise on me, but I'm too stubborn/stupid to accept that
Looking at that pic of Arnie, his lower back (will, the whole thing really) is doing exactly what I though you weren't supposed to do :/
Not everyone is text book.
depends on your body and flexibility.
example.
this is NOT how you should deadlift (in general)
but the man deadlifts over 400kg
Some people are stronger in a certain position than others.
if Arnie can/could squat more with his upper back rounded and kind of rolling forward, then that suits him.
most of us mortals should look at doing it with good form to prevent injury
back injuries suck
take my word for it.
Dezz - I tried smolov jr for 3 weeks.
google it.
I find that pressing doesn't really hit my chest at all... I get much better chest involvement when I'm moving weight across my body... so flyes and 'power flyes'... that said the best chest pump I have ever experienced is from doing the below exercise with cables rather than free weights... not sure why, maybe the constant tension? I find if you focus on bringing your hands together at the end, really flexing your chest and holding it for a second it works really well
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
