did real deadlifts the other night. First time I have done these for weeks. Normally I do straight leg which doesnt seem to wear me out as fast.
Only managed 80kg x 6 reps for two sets. Will be working on them more.
I had a headache yesterday arvo.
went home and did squats.. headache gone.
My shoulder has been hurting for a while... after squats, the pain was gone.
Slept like a baby last night..
Thank you Squats.
Looks like all that pressure on your spinal column is crushing just the right nerves hey? ;)
Getting used to this routine I'm doing, everythings progresssing nicely.
On another note bought some ON gold standard whey, coffee flavour... hnnnnnnngg. If you like coffee you should check it out.
I've been buying PTC's generic protein - WPI; $35/1kg or $150/5kg, usually get the coffee or banana flavours, must say they're not bad at all. Mixes well, consistancy like water, no clumping, not blinded by overly-colourful fancy marketting labels on the product... http://www.ptcbrisba...m/ptc-shop.html
Edited by GHOSTrun
Any Canberra guys looking to get some WPI from Bulk Nutrients right now? I'm going to chuck through an order shortly (maybe today) so figured we could save up on shipping perhaps.
Tom, Mitch, Dan - this is you :P
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
    • Have you noticed if the squeak changes with temperature or after driving in the rain?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
