did real deadlifts the other night. First time I have done these for weeks. Normally I do straight leg which doesnt seem to wear me out as fast.
Only managed 80kg x 6 reps for two sets. Will be working on them more.
I had a headache yesterday arvo.
went home and did squats.. headache gone.
My shoulder has been hurting for a while... after squats, the pain was gone.
Slept like a baby last night..
Thank you Squats.
Looks like all that pressure on your spinal column is crushing just the right nerves hey? ;)
Getting used to this routine I'm doing, everythings progresssing nicely.
On another note bought some ON gold standard whey, coffee flavour... hnnnnnnngg. If you like coffee you should check it out.
I've been buying PTC's generic protein - WPI; $35/1kg or $150/5kg, usually get the coffee or banana flavours, must say they're not bad at all. Mixes well, consistancy like water, no clumping, not blinded by overly-colourful fancy marketting labels on the product... http://www.ptcbrisba...m/ptc-shop.html
Edited by GHOSTrun
Any Canberra guys looking to get some WPI from Bulk Nutrients right now? I'm going to chuck through an order shortly (maybe today) so figured we could save up on shipping perhaps.
Tom, Mitch, Dan - this is you :P
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
