Protein, creatine & BCAA's are what its all about :)
Using Max's supersize protein 5kg 3-flavour pack (cookies & cream is SO awesome!!), with milk
Some sort of ebay creatine powder
And my 2kg amino acid mix from Mr.Supps, consisting of:
- 100g D-aspartic acid
- 250g beta alanine
- 250g L-tyrosine
- 250g creatine
- 250g L-carnitine
- 250g L-glutamine
- 250g L-leucine
- 250g glycerol
Plus take multi vitamins, iron tabs, ZMA tabs, and a little bit of Toco-8 powder in my post-shake with a tablespoon of the AA mix
Found Double-T Sports Nitromine (360 tabs - pretty much amino acid tablets) for $9 a bottle from Supplements Direct (usually $90! wtf??) so I grabbed a few bottles of that with the Toco-8
snake oils. meh. Ive got no problem taking plenty of amino acids, more is > than none :)
- 250g beta alanine
- 250g L-tyrosine
- 250g creatine
- 250g L-carnitine
- 250g L-glutamine
- 250g L-leucine
- 250g glycerol
Man that's a lot of stuff...
Also the glycerol isn't an amino acid just incase you thought it was...
yeah I know :)
bulk buy of the AA's is actually cheap in all honesty, 2+kg was $~90 and it'll last aaaagggggeeees. Mixed in one big tub.
protein and creatine is as it should be.
the tabs? well, ..... taking them "just because I can" :)
- the iron, zma and toco8 is because I reckon my testosterone levels are low due to a number of reasons.
- multi V's 'cause I think its better to take one then not ;)
- Nitromine, well Im a sucker ;) snake oils!!!
* the glycerol is meant to help get the protein/aminos into the muscles? ... "taking glycerol in supplemental form quickly improves hydration and the absorption of other supplements that are taken with it."
If you want a test-booster, grab some dianabol or Trenbolone or Oxandrolone...
Isn't just about any "test-booster" legally purchasable on the Australian market nothing more than snake oil anyway?
- 250g beta alanine
- 250g L-tyrosine
- 250g creatine
- 250g L-carnitine
- 250g L-glutamine
- 250g L-leucine
- 250g glycerol
Geez dude just buy some steak, heaps easier
No; never!! - my 2kg AA mix will last a year, and cost something like $96 all up :)
I dont see the issue - protein, bcaa, creatine, vitamins......
It's entirely the cost when you compare it to something like chicken breast, at least considering you still need to consume food even if you're taking all those supps.
Creatine - Ive had since start of the year
Ammino mix - will last a year (10g per shake makes 200 shakes!), and for the bulk size thats pretty cheap in all honesty
Protein powder - IMO you're crazy NOT to take that shit post-workout, plus the cookies & cream is like a party in my mouth but you're all not on the vip list (sorry!)
Multi V's - Ive always taken them
the rest isnt needed :) granted; snake oils* thought Id try the toco-8 and zma tho as a once-off.
you all jelly at my knees of fury & not needing to squat - that must be it. =p
as for cost, ebay is your friend ;)
hey if you have the money and time to use it, go for it. It might be that 2% that makes a difference.
However unless i was a competing bodybuilder or elite athlete of some sort then i'll spend that 2% elsewhere, usually at jb hifi
So im guessing u dont use sups Simon?
havent seen ya at the gym for ages, been busy obviously
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
