Ill put you to shame Andrew ;)
Damien 90% of the people here take Supps man, including me..
No one is really criticising you for taking them, just silly banter :)
Take your Supps.. Go hard and silence the non believers haha
All I get from this talk is negative crap, if your trying to say if I think I'll take supps and shit I'll get big. Your far from it.
Some positive...
Supplementing your diet with some nutrients you need can help if you don't have time to prepare food. I like protein powder shakes because they are fast to make. So they have their place as a food source and are good value for that.
Taking so called 'pretend' steroids ie: test boosters is a game of fools however.
Things sold as ZMA and others are just fancy zinc tablets. You need more zinc in your diet if you train. Cenovis do a $6 bottle of 100 tablets from coles if you need some (thats the brand I buy). There is a known ratio of B6 and Magnesium even the cenovis stuff has.
Edited by rev210
Some positive...
I dont bother and nor want to go near steroids, test boost and hormones. Like you said "time to prepare food" its just not that its also being off site no fridges, no eating schedule guaranteed.
Only things i take are protein, Bcaa, Multi and a fish oil tab.
Fair enough, but from outside the box only just coming in seems a little different :)
Yup going hard, lost 13kg in 7 months, Still a little away from proving a non believer but will get there..
Thank you for pointing that out. Some light banter mate.
I usually do 1 scoop to 600ml water. Watermelon is good, I'm using blue raspberry which is nice as well. I don't notice any diffrerence with the xtend but I just drink it because I like the taste lawl, so usually lasts me about 6 months.
Some positive...
Currently using Cenovis Vitamin C and Nature's Own Vitamin D (I like chewable stuff). But I went to Coles today and on your advice was about to purchase some Cenovis Zinc (they have a "buy 2 Cenovis, get the 3rd free" offer on at the moment)...but I got sucked into their men's multi which seems to contain the same amount of Zinc/B6 plus a lot of other shit. Here's hoping it doesn't give me headaches like the last multi I tried.
My concern with multis in the past has been their minimal content of each vitamin/mineral, but these are quite large pills (guessing because of the fish oil) and the content was on par with a lot of the Cenovis standalone products.
trouble is that you want to take a dose during the day / breakfast or pre workout and then at night before bed.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
