Ill put you to shame Andrew ;)
Damien 90% of the people here take Supps man, including me..
No one is really criticising you for taking them, just silly banter :)
Take your Supps.. Go hard and silence the non believers haha
All I get from this talk is negative crap, if your trying to say if I think I'll take supps and shit I'll get big. Your far from it.
Some positive...
Supplementing your diet with some nutrients you need can help if you don't have time to prepare food. I like protein powder shakes because they are fast to make. So they have their place as a food source and are good value for that.
Taking so called 'pretend' steroids ie: test boosters is a game of fools however.
Things sold as ZMA and others are just fancy zinc tablets. You need more zinc in your diet if you train. Cenovis do a $6 bottle of 100 tablets from coles if you need some (thats the brand I buy). There is a known ratio of B6 and Magnesium even the cenovis stuff has.
Edited by rev210
Some positive...
I dont bother and nor want to go near steroids, test boost and hormones. Like you said "time to prepare food" its just not that its also being off site no fridges, no eating schedule guaranteed.
Only things i take are protein, Bcaa, Multi and a fish oil tab.
Fair enough, but from outside the box only just coming in seems a little different :)
Yup going hard, lost 13kg in 7 months, Still a little away from proving a non believer but will get there..
Thank you for pointing that out. Some light banter mate.
I usually do 1 scoop to 600ml water. Watermelon is good, I'm using blue raspberry which is nice as well. I don't notice any diffrerence with the xtend but I just drink it because I like the taste lawl, so usually lasts me about 6 months.
Some positive...
Currently using Cenovis Vitamin C and Nature's Own Vitamin D (I like chewable stuff). But I went to Coles today and on your advice was about to purchase some Cenovis Zinc (they have a "buy 2 Cenovis, get the 3rd free" offer on at the moment)...but I got sucked into their men's multi which seems to contain the same amount of Zinc/B6 plus a lot of other shit. Here's hoping it doesn't give me headaches like the last multi I tried.
My concern with multis in the past has been their minimal content of each vitamin/mineral, but these are quite large pills (guessing because of the fish oil) and the content was on par with a lot of the Cenovis standalone products.
trouble is that you want to take a dose during the day / breakfast or pre workout and then at night before bed.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
