Has anyone had experience with the Hex Trap bar?
Looks like it could be a bit easier/safer on the back.
I'm not about to buy one, just a random discussion topic more than anything.
Part of me thinks that it'd allow you to lift more without risking the back, but at the same time makes me think that if the back is supposed to be getting a workout during DLs then you're kind of cheating.
I'm thinking it makes the squat a pull exercise rather than push too.
http://www.t-nation.com/free_online_article/most.../the_trap_bar_deadlift
Edited by ActionDan
Looks like it just targets your legs and traps more due to being able to load more weight onto the bar and retain a more upright/vertical spine.
You're right, somewhat defeating the purpose....though I'd definitely give it a shot myself right now - surely better than not doing deadlifts at all :P
Yes you will, I'm pretty sure your post count will start going backwards now too.
Until you go and squat again.
And don't hate on vagina's a decent one can take an absolute pounding.
Edited by ActionDan
I didn't squat last night when I was supposed to, will I lose all my gains?
If you don't mind contracting superaids and head cancer, you have nothing to worry about.
People keep referring to vaginas in a derogatory sense, implying weakness.
It's been said before, that testicles are pretty damn fragile, but the vagina can take a pounding by comparison.
Take that how you will :D
Edited by ActionDan
It's been said before, that testicles are pretty damn fragile, but we vagina can take a pounding by comparison.
Vaginas ftw.
Exactly. Doing this exercise to avoid an injury that never used to be there is defeating the purpose of building the back stronger.
Stronger back = deadlift more.
Working the rest of the muscle around the problem makes those muscles stronger, but not the injured ones = imbalances
Imbalances are right up my alley, I should definitely get one.
Just gettig freight quotes on racks at the moment.
What?
I'm saying deadlift the proper way after, in this case back, is healed.. Not do something that is a way around fixing the issue.
thoughts about tough mudder?
http://toughmudder.com.au/
was thinking about doing some training for it in september so bit of time to get 'fit'
Hit the uphill cardio with a weighted backpack and run through water.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
