$10 per kg pretty much. Though as you can see diff protein contents - my point being, realistically if I'm going to see any difference from the lower protein amount given my workload. I'm guessing not.
Ayo if you don't care about mixability and lactose, go the concentrate. Personally I can't stand unmixed shit, so I like the isolate. I also have a slight aversion to too much lactose.
Okay, well that will certainly mix easier than the concentrate...but meh...get a sample or a 1kg bag of the concentrate and see what it's like?
I go through this stuff fairly quickly, so even a 5kg bag of a bad flavour or something doesn't phase me.
I find concentrate mixes fine, have had a few brands no clumps. Just don't be lazy and only shake it 3 times.
Edited by Mangune
Either way (including calcium cassinate), easiest way to mix is with a stick blender in a tall cup , I do oats plus frozen blue berries as my breakfast with some non flavoured pure protien. Simple clean up and ready in seconds.
Concentrate is slightly slower to digest vs isolate (both are rapidly absorbed however , so work as post workout pretty well). If you don't care about taste ,Concentrate is the way to go.
ive gone off pretty much all supplements. Only the occasional pre workout if i am real run down after work.
otherwise its just food food food for me. Getting pretty tired of eating chicken, fish and steak though...
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
    • I would tend to agree, especially based on the transfer oil being completely cooked by the sounds of it. I bet it was serviced every 5,000km... Which probably worked out to once every 15,000 real kms...
