I hope you're at least taking progress pics for yourself. One thing I regret is not taking before pics of how ridiculously skinny I was.
Yeah I am - ironically the biggest motivator for me to start doing something was realising how much of a fat f**k I'd become from looking at photos and wondering why I always looked fat haha.
a very rough calculation of my daily protein intake is
15g from tuna
81g from chicken breast
30-80 depending on what I eat for dinner
24g from whey powder
plus a small amount from my morning oats with a splash of milk. Assuming I'm eating a decent amount of meat for dinner, that brings me to around 200g, which is my 1g /lb of lean body mass.
I was eating cottage cheese / greek yogurt for dessert for a while, but I've been trying to keep my calories down.
On an unrelated note, managed to get bench, OHP, deadlift and squats in today, was quite pleased!
Throw in a scoop or a half scoop of protein to your oats in the mourning to help if needed.
I think the ham you buy from the deli in Woollies etc is probably semi processed, not that I can see it as a bad thing as long as nothing is added to it.
Only concerns I have with processed meat are unnecessary additives (salt, sugar, etc), and not really knowing what part of the animal (or God forbid, what animal at all) you're eating. lol.
Ham is a processed meat. Leg ham is less processed than say, the square blocks that are formed from scraps. but it is still processed. It has things added to it, thats what makes ham and bacon taste so different to a pork chop. so, not unnecessary addictives or it wouldnt be what it is, but the ones you don't like.
Edited by jangles
I'd like to think bacon is only smoked to hell, but that's probably not the case :(
Glad I'm not the only one; I could seriously live on cheese, dips and vegetable sticks.
Sometimes I think I might be addicted to cheese. I have looked into it and I know that milk contains the protein casein, which provokes similar effects to opiates when it's turned into cheese. When the casein molecules are digested, they break apart to release tiny opiate molecules, called casomorphins. The process of cheese-making removes water, lactose and whey proteins so that casein is more concentrated.
So maybe you can develop a cheese addiction?
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
