Average girl or lifter girl?
His wife Annie squats 100kg, benches 67.5kg and deadlifts 140kg, she used to train at PTC, in fact she had never touched a weight before lifting in my garage, then in 2010 she deadlifted 140.5kg for a WR in the WPC
There's a few ways you can try to break a plateau, what have you tried so far?
Sidebar: Ordered some of that Bulk Nutrients WPC 5kg of Vanilla, see how it goes.
I did a quick run through using that app Troy uses and it was very interesting to see what it came out with, I could really use some more protein apparently, but I note that when comparing what it thought was the nutritional values for a given food, and I'll used rolled oats as an example as it was the most obvious and it's what I eat for breakfast, it listed no protien in them when the pack lists 5ish grams per 50g serve.
To be fair I was only doing a very quick run through and I can see that you can fully tailor the listing with your own values for foods you eat so you could make it accurate, but off the bat it was a little misleading.
Edited by ActionDan
There's a lot of ridiculously incorrect items in MyFitnessPal's database, sadly the most common things will often have a lot of incorrect stats so it takes a little bit of filtering through to find the right one sometimes. Best done on a PC where you can actually see how many other users have confirmed that the nutritional values for the particular item are correct....then just use that same one each time.
It pisses me off more when I'm looking for something like a piece of fruit or a bread roll, and some f**king clowns somewhere in the world decided that "one large" was an appropriate way to measure serving size.....uhh, what in the f**k defines "large"? 50g? 500g? 235g? Pains me when someone adds something to the database that they obviously created for themselves, yet make it publicly available just to confuse others like us haha
I assumed it was a motorbike reference given he rides one and you have one as an avatar?
Nah, it'll have some sort of reference to his obvious love of calorie counting :P probably something to do with "a tank" being an undefined volume...maybe Birds is winning by successfully f**king with my head without having to actually do anything.
f**k MAN rofl
f**k MAN rofl
Muhahahahaha Troy it's lonely inside your head, get me some friends to play with!
No but really, it was an undefined volume joke.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
