lol, here is my honest opinion Leesh
You look fantastic, no more talk about body recomposition, this is no longer on the table, good job
So now your focus should be to get stronger. This is purely a time based thing, time under the bar
If you are doing big compound exercises, and gradually adding weight, it will come. You are not looking at competing in powerlifting or anything else, so dont push it if your not comfortable, only add weight when you think you can
With cardio, if you enjoy, why stop? It hasnt done any damage to your physique, it will slow your progress on strength gains, just be honest and work out whats more important.
I'll see you and Birdy in October I hope
Good work
Only 100 are on the site, the next 79 are subscription only
Number 37 seems to be the one most refer to as the best, its been posted on many PT's Facebook pages and websites
As I explained thats the process Martin used to get in that condition I posted a pic of
And THAT'S why I wouldn't have said that Birds lol
Walked into that one.
Past the point of caring mate. When you spend 8 months patiently trying to help someone who came to you for help...when they constantly ask for your advice but don't follow through on it how you want them to...then complain that it isn't working for them (despite numbers to the contrary), swearing black and blue that they did exactly what you said...and instead of a simple thanks, you get a heap of blame for the dissonance that person feels...it's hard to keep giving a shit.
Like sands through the hourglass?
When TTT has finished riding it, I'll grab the llama for you :D
This times eleventy.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
