lol, here is my honest opinion Leesh
You look fantastic, no more talk about body recomposition, this is no longer on the table, good job
So now your focus should be to get stronger. This is purely a time based thing, time under the bar
If you are doing big compound exercises, and gradually adding weight, it will come. You are not looking at competing in powerlifting or anything else, so dont push it if your not comfortable, only add weight when you think you can
With cardio, if you enjoy, why stop? It hasnt done any damage to your physique, it will slow your progress on strength gains, just be honest and work out whats more important.
I'll see you and Birdy in October I hope
Good work
Only 100 are on the site, the next 79 are subscription only
Number 37 seems to be the one most refer to as the best, its been posted on many PT's Facebook pages and websites
As I explained thats the process Martin used to get in that condition I posted a pic of
And THAT'S why I wouldn't have said that Birds lol
Walked into that one.
Past the point of caring mate. When you spend 8 months patiently trying to help someone who came to you for help...when they constantly ask for your advice but don't follow through on it how you want them to...then complain that it isn't working for them (despite numbers to the contrary), swearing black and blue that they did exactly what you said...and instead of a simple thanks, you get a heap of blame for the dissonance that person feels...it's hard to keep giving a shit.
Like sands through the hourglass?
When TTT has finished riding it, I'll grab the llama for you :D
This times eleventy.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
