Just an update on the protein testing...
DTS were nice enough to send me confirmation that they got my enquiry, but not to actually reply to it (been a few days now). So I will attempt contact with the other Melbourne based lab.
Reading a blog that talks about the dangers of melatonin; some of these reader comments are hilarious
http://www.marksdailyapple.com/before-you-close-your-eyes-make-sure-theyre-open/
I think melatonin should be banned or at least have warnings on it.I used it every night for 3 months and I gained 20 pounds!
Im someone who has always been in shape and never weighed more then 120 pounds,so that kind of weight gain was unheard of for me.
I really think the melatonin played a role in that weight gain.I was also crying and sleepy all the time.I thought it was safe to take because it is marketed as a natural supplement.But it in fact gave me symptoms of being bipolar or having a mental illness instead!
Im a very health conscience person. I dont eat meat or poultry, just a little fish. I take a slurry of supplements. I exercise regularly doing lite weights, cardio boxing, yoga and pilates! Im an active mother of 4 kids and work and have always maintained a size 6 (other than 25-30 pounds of weight gain during pregnancy) Recently I used malatonin 3mg 3-4 times a week for 2 months and I have jumped to a size 8. I have increased my exercise and decreased my carbs and I still gained weight. Yes, I am responsible for putting that pill in my mouth at night! I assure you its not my diet or lack of movement!!!
Why are people so stupid. Why would you continue to dose yourself up on something if it was having negative effects
People think that just because something can be bought without a prescription (in the USA anyway), then it's no holds barred. And some people think that stuff with a prescription is completely safe too!
I just thought it was funny people blaming 20 pounds of weight gain on a 5mg hormone, as if the weight magically appears out of nowhere. I don't care what effect it has on metabolism, in the end you control what goes into your mouth and what exercise you do. Trying a new medication? Track what you eat and the exercise you do in case it changes.
Someone put it best there - always people looking to abdicate personal responsibility onto something else. Then they go and say to ofhers DON'T TAKE THIS STUFF IT CAUSED ME TO EAT YUMMY DESSERTS WITH EXTRA SPRINKLES EVERY NIGHT. It's the "maccas made me fat" mentality. Amazing how my diet and exercise remained the same, consequently didn't gain any weight on melatonin.
It seems true from my searching, however it didn't come without penalty...there were hundreds of cases settled in court; they paid hundreds of millions to victims in class action and individual law suits. People should be in jail over it, though.
Birds: Supp testing update?
Markos/all: What's the conventional wisdom on where to drive from with the squat, I find the weight shifting forward for me and I'm driving more from the ball of my foot. I've been told different things heel vs ball, but in my head if I go and jump bare foot, it ain't the heel that wants to land first and take the impact.
I've ALWAYS heard driving from the heel. If you're finding yourself putting more weight onto the ball of your foot, perhaps try a wider stance - that helped for me.
I'm already pretty wide in my opinion, maybe a bit outside shoulder width and I go low bar.
Interestingly physio advocated ball drive too, she said mechanically it's where you are supposed to push from.
Well yeah, under normal circumstances lol. I'd think when you've got 100kg+ on your back, it's in your best interests to drive as directly as you can by employing less joints directly into the movement...but I've never actually been shown how to squat by a professional, just multiple bros :P
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
