I was trying to go ATG as in calves touching hammys, basically as low as I can go, I find that easier than stopping half way down or a bit below parralell which feels like it would be a heap of pressure on the knees.
Not yet, considering it though. Current physio has me doing nerve glide/mobility exercises but after paying close attention during stretching etc I feel as though it's coming from the lower back.
been to a chiropractor?
my little brother had a back issue when he was younger, turned out his hip was out of place slightly resulting in one leg being longer then the other.
My legs are out by around 3cm every time I get trigger point :(
as low as you can go and as low as you can go with correct technique differ vastly. going ATG and compromising form isn't a good thing.
Even though you stretch etc. daily, do you feel you're making any significant progress? Maybe you need to review what you're doing if it isn't effective?
Buy starting strength or something that explains technique in depth, that way you can refer to it whenever you're in doubt to coach yourself.
I'm not sure if this will answer your question Dan, but I think these videos are worth a watch anyway. I watched them last night as I'm having an issue with my knee bending in during squats. It's a five part series called 'So you think you can squat' Here's a link to the first one
Easier to just go and see Matt again. All I need to know is if the butt should be rounding in under/tucking under naturally or whether that should be avoided.
I reckon that's a good idea.
I dont think It's natural to the squat, you're not squatting any lower, you're just pushing your arse down. That's my guess. I'll let someone in the know answer.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
